No More Coolant Pump Noise?
Discussion in 'Gen 2 Prius Main Forum' started by ajayre, Jan 14, 2012.
  1. ajayre
    ajayre Junior Member
    44
    UK
    Every time I turn my Prius on and off I hear a whirring-pumping noise. I believe this is the thermo coolant pump (please correct me if I am wrong).
    A couple of weeks ago the dealer replaced a slowly failing 12V battery and replaced the brake discs and pads.
    Now the whirring-pumping noise is gone! Should I be worried? What could have changed?
    Thanks, Andy
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I believe the pump noise you are hearing is the pump that fills the thermos bottle. The 12v should have nothing to do with the pump noise! Hal
  3. ajayre
    44
    UK
    You mean the pump noise I am no longer hearing. That is my question - should it ever stop unless something is broken?
    Andy
  4. puckdrop
    puckdrop Junior Member
    23
    Nottinghamshire, UK
    Correct me if I'm wrong.. but I read somewhere that the UK version doesn't have the coolant thermos flask ? The sound you're hearing is more likely to be the hydraulic brake circuit pressure charging up ?
  5. ajayre
    44
    UK
    That would be interesting because the sound disappeared after the brake job! Hmm...
    Andy
  6. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Could be the brake accumulator pump. That runs whenever the accumulator needs pressure.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The UK model does not have the thermos bottle, so no transfer pump. Most likely you were hearing the brake accumulator pump. It makes more of a ratcheting sound. If you want to hear it, press and release the brake pedal three or four times. That will use up the brake pressure and force the pump to run.
    Tom
  8. Hal W
    Hal W New Member
    872
    53
    Well I guess that is why he can't hear it, but he could before the 12V change!!!!I never even notice location! Another 60's moment.. Hal
  9. uart
    uart Senior Member
    4,215
    1,200
    Australia
    No not the 12V battery, they also did the brake pads, they probably did the brake fluid as well. There could be a little less movement now in the calipers or some other subtle change that is triggering the accumulator pump a bit less.
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It's probably because of both fixes. The 12V battery replacement makes the brake accumulator pump more effective (not trying to pump on low voltage) so it only runs for a sec. or so. The brake pad replacement stopped it because it no longer has to move the pads as far.
    I'll bet it still "burps", it just doesn't do so for a long period.
  11. ajayre
    44
    UK
    Previously I heard the noise after every time I turned the car off (as well as when turned on). That would still be the brake accumulator pump?
    It's reassuring that the noise going away actually means the car is working better!
    Thanks, Andy
  12. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    How much did the dealer charge for disc and pad replacement. I am about to change mine and have sourced all the parts front and rear for £70 and will change them myself. The pads still have about 50% life left but discs are very rusty so will change everything. Mileage 80K.
  13. ajayre
    44
    UK
    460 for parts and labour. It's expensive but I don't have the skills or equipment to do it myself...
    If I pump the brake pedal I can get it to make a whirring noise. Also if I turn it off with the brake pedal pressed. But it doesn't sound quite the same as the noise I was thinking off. So maybe my car was sick for a long time and I didn't know it.
    Andy
  14. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Maybe the new brake fluid quietened it down? :confused:
