No More "I Agree"??
Discussion in 'Gen 2 Prius Main Forum' started by Tideland Prius, Sep 1, 2007.
  1. Winston
    Winston Member
    614
    SF Bay Area, California
    Is the software version different on the '08? Any new POI information on the 08 DVD?
  2. mongoosescott
    mongoosescott New Member
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 31 2007, 10:07 PM) [snapback]505328[/snapback]</div>
    No I agree, just a warning that goes away by itself.
    --Scott
  3. rlaird
    rlaird Junior Member
    <div class='quotetop'>QUOTE(Winston @ Nov 2 2007, 08:27 AM) [snapback]533848[/snapback]</div>
    Since my '08 Prius is my first Prius, I don't have any way to know what's different. The nav and bluetooth lock out after you break 3 mph. As noted by others, the intro screen appears for a few seconds then goes away.
    I'm hoping there will be a Lockpick for the '08 that will let me "unlock" the nav while moving.
    While driving, I can point to a new spot on the map and then tell it to go there... that's better than nothing, but if I have an address and don't know where it is, then I'd have to stop to enter that info. There are 7 (I think; will have to confirm) "quick" locations you can set up... once set up, you can change to one of the them while you're moving. Similarly, the bluetooth lets you call people by number or by name (if you set them up prior with voice tags) while moving, but you can't dial on the screen. (I can dial using my phone, though, which is good!)
    My wife's Acura MDX has DVD navigation, and the Prius '08 nav is probably a bit better overall, but they are both excellent. The Prius has a detour option that the Acura doesn't, but the Acura has a joystick which is much better than trying to be precise with your finger on the Prius.
    -- Robert
  4. priusbeast
    priusbeast Junior Member
    Part Number?
    Does anyone know what the latest navigation DVD part number is?
  5. Tideland Prius
    16,634
    Someone over at GreenHybrid (dang?) has the part number.
  6. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    The lockpick is the best device i've ever purchased.
