No mud flaps on the 2010? Not even as an accessory ???
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MSantos, Jun 21, 2009.
  1. ronng
    ronng New Member
    redding, ca. 96003
    oh, price of set of 4 mudguards is $49.00 plus tax
  2. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
  3. pielev
    pielev Junior Member
    Sherbrooke, QC, Canada
    I
  4. pielev
    I
    I found a set a 4 on the Prius 2010 from the Prius chat Store.
    They fit well but I learned through the process that it was a marketing reason hogwash that incited Toyota not to put mud guards on the Prius 2010. There was absolutly no technical reason according to Toyota Canada. Now we all have to write them and beg fro Mud flaps to be standard as they were on Prius 2008 and 2009.
    If everyone shout at them they will put them on as standars as before.
    Thanks to Prius Chat Store my problem is solved because here in Sherbrooke QC the city of 200,000 uses gravel rocks instead of salt to be ecofriendly in the winter.
    Pierre Levesque
    Sherbrooke QC Canada
  5. Mendel Leisk
    42,372
    One thing: it looks like some drilling is required to install the mudflaps. It would be better if there was some sort of nylon/plastic grommets in place, suitable for self-tap screws.
    Kinda related: what about the plastic wheel covers over aluminum alloy rims? Are they prone to trapping grit and salt?
  6. Joe166
    Joe166 New Member
    720
    97
    South Florida
    The"drilling" needed could be done with an ice pick. Not a big deal.
  7. Mendel Leisk
    42,372
    Well, my concern is drilling a fresh hole into the sheet metal. A factory punched hole (prior to painting) filtted with a plastic grommet designed for self-tapping screws will not start rusting.
    As it stands, your best bet would be to determine optimum location, find some aftermarket grommets designed for taking self-tapping screws, drill to suit the grommets, prime and touch-up paint, and so on. But that's a fair bit more run around, due to Toyota's decision.
    Also, if you remove the mudflaps, and periodic removal for cleanout is a necessity wherever salt and sand are used, those direct drilled holes will get loose and even rustier.
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    The two installations that I have done did not require drilling into sheet metal. Just the heavy plastic wheel well liners.
    Like Joe said it could be done with an ice pick. No chance of rust.
  9. Mendel Leisk
    42,372
    Thanks, good to know.
