No power mystery
Discussion in 'Gen 2 Prius Technical Discussion' started by Bart47, Dec 28, 2022.
  1. Bart47
    Bart47 Junior Member
    23
    Ks
    This is, unfortunately, a multi-layered backstory that complicates the basic problem of no power. I had stopped driving my 2006 Prius after getting a battery overheating code. It sat for 4 months but I would start it occasionally. Then, this weekend I took the hv battery out to check the cells. I did not try to start it before I took it out, however. I found one obviously bad cell which I replaced and put the battery back in. I may not have seated the orange safety switch the first time I tried starting it, however, but did set it properly after that. I’d charged the 12v battery ahead of time, but there was no real sign of power, except what seemed to me to be a weak power button light and some slight power up sounds when putting on the brake and pushing the button. No dash lights, no screen power. There was 12v power at the jump location. This story, so far, is probably fairly common, and the next part is where some will tune out, so before you do, please let me know what you think the problem is before you read the rest. The other part that may or may not be the problem is that during the time it sat, apparently rodents had gotten in and done some damage. I have taken the dash completely out to look for damaged wires, and so far have only found a couple that could account for the dash lights being out, but they were out the last time I had started and driven it, maybe 3 weeks ago, and it seemed to run fine otherwise, (prior to throwing the code again). I plan to use an endoscope to inspect the rest of the wires that I can’t get to still, but I am not seeing much wire damage, but they were both in the dash and under the hood, and probably in the trunk as well. So, what I am asking for is a checklist of what I should check to get things at least back to a baseline of power to start. I should be able to take it from there. There is 216v at the battery side connection, after the orange safety switch is installed. I am not seeing any voltage on those two main connection points right beside the ones closer to the cells that I got the 216v reading at. Should these points also show full voltage, or only once you are in a ready condition? Any help would be greatly appreciated. Thanks.
  2. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    Have you ever done the Combination Meter repair that prevents the Dash Display and lights from starting properly when putting the vehicle into READY?
    Just search Gen 2 Prius Combo Meter Repair on YouTube or any Prius forum. Tons of info about it.
    Again, may just be the Combo Meter capacitor replacement repair is necessary.
    They will only show Voltage when the Prius is in READY. That clicking you hear from the back whenever you start your Prius are contacter relays engaging at that exact point so High Voltage becomes connected to rest of the car.
    When you shut the car off, the contacter relays disengage and Voltage is confined to the Hybrid Battery only.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Don't overlook the obvious.
    What voltage exactly do you see for the 12 V battery ?
    12.0 indicates half discharged......under no load.
    Under load, it might fail completely.
    Also the negative 12 V battery cable where it connects to the frame/body is often a problem.
  4. Bart47
    23
    Ks
    I will definitely check on the combination meter repair procedure, thanks for that. And also thanks for the info on what really happens getting to the ready state. That makes complete sense.
    I have tried two different batteries and both were at least 12.4. One is pretty much brand new. I did check for continuity with my cheap multimeter, and it showed as good, but will probably add a jumper to ground next time, just to be sure, so thanks for that, as well.
    I imagine there are a number of conditions that the computer must see as correct, before it allows the ready state. Are these conditions listed somewhere on this board, would anyone happen to know? I might try confirming as many of these as I can.
    Thanks again.
  5. TheLastMojojomo
    232
    181
    US
    Yes the Combination Meter Repair may explain the no dash lights.
    Note that the Prius will still run and drive even if the combination meter display isn't working. Also all dash lights will cease to work as well... but the car will still enter READY and drive.
    It could be lots of things...
    Maybe you blew a fuse somewhere when installing the 12V Battery... Maybe you reassembled the HV Battery incorrectly...
    You'll have to do the leg work on process of elimination. I can't really do much over the internet.
    Does the Prius go into Ignition On at least?
    Power Button turns Orange after two-clicks of the Power Button WITHOUT foot on the Brake:
    If this is the case you should be able to at least read codes.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,108
    2,008
    NJ-USA
    Turn on various devices- headlights, flashers, try to go to accessory and ignition on mode- try wipers heater, etc. What works at all vs not?
