No power to either power outlet in the car and it's not the fuses. Please help!!
Discussion in 'Gen 2 Prius Main Forum' started by Susan Potter, Aug 16, 2018.
  1. Susan Potter
    Susan Potter New Member
    Daytona Beach, Florida
    I recently purchased a used 2005 Prius and didn't realize at the time that both power outlets did not work. I found the fuses under the dash and replaced the ones that were bad, neither outlet worked. I then removed the panel under dash to see if the wires were loose, they weren't. While doing that I discovered 2 more fuses attached to the wiring, they were good. I was able to find a power meter to and checked the inside of the outlets themselves, it read no power. Does anyone have any suggestions, I can't afford to take to the shop right now, but I need a charger for my phone/gps since I'm in my car most of the day..... HELP!!!!
    49,691
    welcome!
    if you had to replace fuses, that means something was causing them to blow. you might have shorted wires somewhere, and will have to trace them to the power source.
    i assume you are aware that the outlets are only on when the car is ready.
    you can find wiring schematics at tech info.toyota.com
    Raytheeagle likes this.
  3. Mendel Leisk
    38,874
    Let's hope it's just this?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Agreed;).
    See you are back to your old avatar(y).
  5. JC91006
    16,493
    8,403
    The outlets should work even in accessory mode, car does not have to be ready.
    There are some fuses in the engine compartment too. See if any of those are blown.
  6. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Not sure if the situation is the same, but this happened in a Suzuki XL7 one time. My son caused both to fail somehow. I think for safety they have a built in overload where the wires connect to the outlet. I had to replace both outlets with new ones. I replaced them with aftermarket USB sockets since we don't smoke.
    ITBland and bisco like this.
  7. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    Yes, if you look at the back of the outlet, under the connector is a fusible link, unfortunately it does not visibly burn. Take the voltmeter an check the power at the wires (back probe the connector) and then check both sides of the link.
    Salamander_King likes this.
  8. Mendel Leisk
    38,874
    Or just check for continuity, Ohms.
  9. Fredsimm
    188
    117
    Tupelo MS
    Thanks for clarifying. The pic helps a lot. If the leads have power, it's definitely the outlets.
    ITBland and Salamander_King like this.
  10. Susan Potter
    We did use a volleyed and I showed no power. I so change out the fuses anyway to see if that works, if not I'll change out the outlets. We true to follow the wires, but could only be so far. I found the fuses in the hood and they all tested good...
  11. ITBland
    433
    272
    The power outlets are run by fuses 19 & 21 in the dash fuse box (15A) in a 2005.
