No power to moonroof or dome light or map lights please help
Discussion in 'Gen 3 Prius Technical Discussion' started by Evoking, Aug 6, 2020.
  1. Evoking
    Evoking Junior Member
    91
    16
    Pomona
    Hi I’m now here I just bought a 2010 Prius with solar panel and and moonroof but it didn’t work when I got it but I thought it was just a fuse or something but I really don’t know where to check so you guys can help me find the fuse or relay that might be out that would be awesome thank you
    48,995
    i know there are fuses under the hood, in front of the steering wheel, and in the cabin by the drivers left foot.
    is there a diagram in the o/m?
  3. Evoking
    91
    16
    Pomona
    Yes but I don’t really understand them but I have the manual I might just have to read up on it I just don’t know if anyone have experience that before
  4. Evoking
    91
    16
    Pomona
    Update problem fixed so I did what you said I checked all the fuses and all of them were good but then I remembered that my brothers wife’s little brother use to work for Toyota so I called him I took it down yesterday and he ended up taking a small part of the headliner turns out that the main plug was unplugged and so there was no power going to the dome light moonroof ect so all is well thank you so much for your help
