No power
Discussion in 'Generation 1 Prius Discussion' started by Lost and confused, Feb 2, 2019.
  1. Lost and confused
    Lost and confused New Member
    Wisconsin
    2002 Prius
    I am trying to figure out what the domelight cigarette lighter remote side mirrors radio and MFD have in common. I’ve checked all the fuses all fuses seemed and test out good but all of the above have no power this is on a 2002 Prius. I Purchased the car this way the car is in immaculate shape except for this problem. Does anybody out there have any thoughts! Thank you in advance.
  2. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Check for a common ground for all these units. I am looking now through the schematics and if I can find a common circuit (Power or ground) I will post.Good luck.
  3. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    Verify if dome light has power at bulb connection and if bulb is good. also there are 4-5 connectors (junctions) under the center of the dash that are common to all those circuits. Power and grounds are tied through these connections. Unless you have discovered the issue, these circuits may be part of your problem. Junctions 24,25,26 27 & 28 and their related circuits could be related to the problem.
