No ready light, no start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Keeley, Oct 27, 2017.
  1. lukesemperfi
    lukesemperfi Junior Member
    Stevenson Ranch, CA
    I should add this. I haven't changed any of the batteries since I bought the car. I'm the original owner of the car. The most recent work done on the car was due to my head gaskets being blown. See list of work and parts done. Does it look like the inverter pump was changed. He said the reason my head gaskets were gone were because it was possibly overheating.
    SUPER LONG LIFE COOLANT
    0W20-SINGLE QUART (W
    FIPG OIL PAN
    GASKET KIT, ENGINE O
    REPLACEABLE ELEMENT
    VALVE SUB-ASSY, VENT
    TENSONER ASSY, CHAIN
    INLET SUB-ASSY, WATER T-STAT
    WASHER, PLATE HEAD BOLT
    GASKET DRAIN PLUG
    GASKET
    BOLT HEAD
    PLUG, SPARK
    RESEAL FUEL INJECTORS
    CLEAN FUEL INJECTORS
    CLEAN OUT CARBON BUILD UP EXHAUST PIPES
    ALL NEW GASKETS IN EXHAUST CONNECTION
    REPLACE HEAD GASKET
    RESEAL WATER PUMP
    RESEAL OIL FILTER HOUSING
    RESEAL TIMING COVER
    CLEAN OUT INTAKE
    CLEAN THROTTLE BODY
    CLEAN CARBON BUILD UP ON PISTONS
    REPLACE PCV VALVE
    SPARK PLUGS
    NEW HEAD BOLTS AND WASHERS
    TIIMNG CHAIN TENSIONER
    OIL CHANGE
    REPLACE COOLANT
    VALVE JOB
    I'll be back with fuse information.
  2. lukesemperfi
    Stevenson Ranch, CA
    Fuses are all good. Help!
    52,841
    welcome!
    i would suggest more gas. if that doesn't work, check the 12v health. if that isn't it, disconnect the 12v negative for a few minutes. if that doesn't do it, tow it to a dealer.
    all the best!(y)
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Your inverter pump might have failed already. Check the AM2 fuse. If its bad, replace it. The READY light should come on.
    Have you checked if you have enough fuel in the car?
    Check the voltage on your 12V battery, if it is within spec. If its not, the car would never start.
    Can you get the car scanned pls?
  5. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    If all the suggestions here don't solve your problem, I suggest you ask your question in a Gen 3 forum, as the people over there will have better advice. This a forum for Gen 2 Prius.
    #45 dolj, Mar 23, 2018
    jerrymildred and SFO like this.
  6. lukesemperfi
    Stevenson Ranch, CA
    You nailed it! It was the 12v battery. The voltage meter read 9.2v. Cost: $250 installed (mechanic friend who lives 100 miles away from me). He had a code scanner but still had a hard time figuring it out. He resorted to taking his Prius battery out and putting it in mine. When he did that, the car started. I don't know if he tested the battery for it's voltage after he took it out or before. Will ask him. Thanks for your input. He said I was lucky it wasn't the inverter. My question is, why the heck doesn't the error lights just say battery and instead a whole slew of other error lights! Same with the oil, now that it has 170,000, it burns oil. One time I checked it, there was no oil on the stick!!! Needless to say, now I check it every week. Anyway, thank you.
  7. lukesemperfi
    Stevenson Ranch, CA
    I had checked the AM2 fuse before sending it to the mechanic. It was good. And yes, it was the 12v battery.
  8. bisco
    52,841
    eternal questions, unfortunately.:cool:
  9. lukesemperfi
    Stevenson Ranch, CA
    I had not idea I was in the Gen 2 forum. Oops. Thank you. I'll definitely remember that for next time. The problem was the 12v battery. Phew!
    Warwagoness and jerrymildred like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Glad it was a simple fix! Those are the best kind. ;)
    That's because, when the battery gets low, the computer gets stupid. It's like when a hypoglycemic person's blood sugar crashes so hard they can't figure out why they can't think straight. Happened once to my wife. Scary! And the thing is, when the car is on, the charging system is feeding roughly 14 volts to the 12V battery, which masks any symptoms. When it's off, the car doesn't know much of anything. Catch 22.
    I guess there are some fancy cars that have oil level switches. But they are just pass-fail and don't tell you how soon your oil will be too low. It's the driver's job to check the oil regularly. Since neither of mine are burners, I only do it every few weeks.
  11. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Ibbetvif I could design some kind of resistor LED device to be stuck on a section of the valve train, that would indicate if the oil is extremely low.
  12. Dawood
    Dawood New Member
    hi I changed prius 2 transmission and now it's not starting
  13. Kmun
    Kmun Junior Member
    Oregon
    Sub Code Question: I have a basic code reader OBDII. No codes are showing. Where might I get a Sub Code reader or is this a dealer-only device?
    My Prius will start periodically with a disconnect and re-connect of the (new) 12V battery and a lucky futz with booting from one push power (accessory mode), hold Info button, three or four head light on offs). This use to work consistently to get the "Ready" light and run as normal. I thought this was consistent with the dash cluster failure. Changed that cluster out and still have the problem. Any ideas?
    #53 Kmun, Apr 11, 2019
  14. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Get a tech stream software installed on a laptop. That would help you access all the codes, including the sub's.
    What's the state of the 12C battery you got there?
    Has it being replaced before?
    What's the mileage on your Prius?
    Answering those questions, would help.
  15. Lib
    Lib Junior Member
    34
    Zambia
    l have similar problem with my prius 05. 3 months ago, after replacing 12v battery one day Red triangle lit,thinking its gas about to run out rushed to station and topped 5 liters continued driving and parked at the market .After shopping tried to start no READY .so towed car home while in neutral . tried to jump start no READY. after parking it for a month l had 12v battery charged with a charger,tried to start no READY started scanning with elm327 (no GTOs, 2 incomplete Readiness mornitors catalyst and oxygen sensor) the battery went flat,jump start to my surprise READY.
    After driving for some days run out of gas drove car on electricity until HV battery bars on screen finished, no READY .Added 3 liters and jump start, no READY .towed it home in neutral .added 10 liters more scanned ,connected bigger battery from another car(reading 13V),no READY .Tried the following
    1.check fuses OK
    2.connected directly to fuel pump OK
    3.shorted brake light switch No READY
    car turns ON and able to on park and neutral only NO READY
  16. Lib
    Lib Junior Member
    34
    Zambia
    the switches on the HV battery are closed all the time when trying to start the car
    Also no power to the fuel pump
  17. jerrymildred
    11,517
    14,167
    Tampa, FL
    This is alarming. You may have run down the traction battery below the point where it will spin the engine, which fits with the following.
    When starting that car, the traction battery spins the engine with MG1 up to about 1,000 rpm, waits for the oil pressure switch to close, then starts the ignition and the fuel pump. No battery power, no engine spinning. No engine spinning, no fuel or ignition.
    SFO and bisco like this.
  18. Lib
    Lib Junior Member
    34
    Zambia
    HV battery reading 200V.where is oil pressure switch ?
  19. jerrymildred
    11,517
    14,167
    Tampa, FL
    You're a couple volts below the normal operating voltage for a Gen 2, but it should still start. However, every time you try and fail to start it, you'll reduce the battery charge even more, so you really need to find out why it's not starting before you run the battery too flat.
    No idea where the oil pressure switch is. Now that I think more about it, I'd think the fuel pump would start when the engine starts to crank so it has enough pressure ready then the injectors and ignition come on.
    Perhaps a pro like @Elektroingenieur @Patrick Wong could help understand the sequence and point you in the right direction. We have some other really knowledgable people here, but these two just came to mind.
  20. Patrick Wong
    18,210
    6,517
    Forget the oil pressure switch.
    1. Disconnect the 12V battery so the ECUs can reset.
    2. Fully-charge the 12V battery.
    3. Reconnect the 12V battery.
    4. Make the Prius READY.
    5. If the Prius does not become READY, note the fuel gauge reading.
    6. It would be a really good idea for you to not run out of gasoline; and when you refuel, to add more than 3 liters at a time. The Prius cannot detect that fuel has been added if you do not add at least 4 US gallons (15 liters) at one time.
    7. If the Prius hybrid vehicle ECU thinks that the car does not have fuel, it will not try to start the engine.
