No Ready Mode after 12v Battery Change
Discussion in 'Gen 2 Prius Main Forum' started by Fredsimm, Jul 8, 2019.
  1. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Yes I've searched. My Prius battery died completely. The 12-volt one. I replaced the battery with an OEM replacement. Now it won't go into ready mode. I have power to the power button and to the park button. I have no headlights no dome lights no brake lights. If I press the power button I don't get any dash lights. I press it again I get a check engine light. I do hear the brake booster humming. I did attempt to jumpstart when it died. Maybe I blew a main fuse. Any help would be appreciated. Thanks.
    #1 Fredsimm, Jul 8, 2019
  2. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    That sounds like it would be the AM2 Fuse, #31 in the attached illustration.
  3. Fredsimm
    188
    117
    Tupelo MS
    Thanks, I will check tomorrow.
  4. davecook89t
    1,093
    832
    Actually, if the blown fuse was caused by a botched jump start, the fusible link is the more likely candidate. It is contained in the long plastic piece on the left of the fuse box.
    donbright likes this.
  5. Fredsimm
    188
    117
    Tupelo MS
    I forgot to mention that a fully charged jump box will light up the dash at the fuse box jump terminals.
  6. Fredsimm
    188
    117
    Tupelo MS
    Also, I read someone with the exact same symptoms needed the 120 amp fuseable link on the positive battery cable. I just read there's one in the fuse box too. 2 fuseable links. Which one is bad.
    #6 Fredsimm, Jul 9, 2019
  7. Leadfoot J. McCoalroller
    8,278
    7,788
    Pennsylvania
    2018 Prius c
    You'll need to inspect and/or put a meter on them.
  8. Fredsimm
    188
    117
    Tupelo MS
    I see a small break in the one under the hood.
    davecook89t likes this.
  9. Leadfoot J. McCoalroller
    8,278
    7,788
    Pennsylvania
    2018 Prius c
    That will do it. If you think it got burnt by an error in jump-starting, then it's probably safe to replace it and get on with your day. If you aren't sure why it burned out, you might want to do more detective work before risking burning another one.
    donbright, Skibob and davecook89t like this.
  10. Fredsimm
    188
    117
    Tupelo MS
    We are rolling again. Fusible link under the hood and a couple fuses in the fuse box. It went to ready and all warning lights went off.
  11. Fredsimm
    188
    117
    Tupelo MS
    Thanks for your help.
    donbright and davecook89t like this.
  12. Mendel Leisk
    42,306
    Check the voltage at the battery posts too, just to get that out of the way. And all the battery cable connections.
