No Ready, No Error Codes, 2002
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by beachdaman, Aug 28, 2019.
  1. beachdaman
    beachdaman New Member
    Los angeles
    2002 Prius
    recently swapped an hv battery, 12v battery, ignition, immobilzer and ECU, into a non running 2002 prius with low mileage engine from a running prius with high miles and leaking head gasket. did a “handshake” by jumping OBD to pair the car’s ecu, keys, etc. But I’m still not getting a ready light. Im also not getting any error codes.
    Im suspecting the inverter is bad based on the fact I dont see the inverter pump moving water. But didn’t want to swap the inverter until I got some feed back from the community. Thanks for any thoughts or insights.
    iPhone ?
    51,139
    wouldn't that be a bad pump, or fuse?
  3. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    Is one of those ECUs the one where you need to leave the car in IG-ON for 30 mins to initialise it to the car?
  4. Patrick Wong
    18,200
    6,492
    Yes
