No sound from speakers
Discussion in 'Gen 4 Prius Audio and Electronics' started by turbo1, Jun 12, 2019.
  1. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Some speakers (normal plus tweeter in one package, for example) have capacitors in them to filter the audio to appropriate frequencies to match them to the relevant frequency responses for each speaker.
  2. turbo1
    turbo1 Junior Member
    36
    usa
    it seems i have to change head unit because it has sone problem
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    It seems odd that it doesn't have the JBL - I thought - maybe @The Professor can confirm - that all PRIUS had JBL sound systems?
  4. turbo1
    36
    usa
    guys please tell me according to this pic does it mean that my parkings are working or not?
  5. The Professor
    598
    809
    UK
    Excel
    I can't speak for anywhere else, or any other time, but when I purchased mine in 2017, here in the UK, only the higher models had JBL by default.
    alanclarkeau likes this.
  6. The Professor
    598
    809
    UK
    Excel
    Some interesting settings that I'd love to tweak at the bottom of that page...
    To answer your question though... It says "undetect" next to most of the front sensors, which means they're either not plugged in or not working.
  7. alanclarkeau
    7,045
    7,592
    Ah - another regional difference besides whether they've got knobs or not - base and the top iTech ($8000 dearer) had the same entertainment unit - except the iTech had Nav & DAB.
    What has yours got?
  8. The Professor
    598
    809
    UK
    Excel
    Mine is the highest one, called the Excel in the UK. Below that you have Business Edition Plus, Business Edition, and I forget what the base level is.
    Mine has JBL and the JBL orange stickers everywhere. I think it has all the extras that are inside the car. Unfortunately, that did mean I had to get the 17" wheels.
  9. turbo1
    36
    usa
    guys the problem was solved the problem was with head unit, changed it and sound comes back
    frodoz737 and krmcg like this.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    Maybe because he took them OFF OF THE CAR when he removed the front bumper cover ??
    krmcg likes this.
  11. The Professor
    598
    809
    UK
    Excel
    Exactly.
  12. turbo1
    36
    usa
    guys i removed the front bumper only, but as you can see on this pic, the rear ones are also undetected i wonder why?
  13. The Professor
    598
    809
    UK
    Excel
    This is a common symptom of wiring or sensor damage. For example, if one or more sensors shorted to ground during the impact or bumper removal, then that can cause damage to the control module. If one or more is still shorted to ground, then that can cause issues detecting the other sensors.
    Another thought is... During the impact did another vehicle hit the rear bumper?
  14. turbo1
    36
    usa
    does it mean i have to change control module? techstream did not show any codes about control module.
  15. The Professor
    598
    809
    UK
    Excel
    I would first check each of the sensors. Unplug them all, and plug in one of the ones that are known to be working. Check to see it's working, then plug in another, and so on.
