no spare tire
Discussion in 'Gen 5 Prius Main Forum' started by amb2, Dec 11, 2024.
  1. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    I'm not using the Slime Kit, but a Slime device that is simply an air pump that connects to the cigarette lighter for power. It is simply filling with air, not the repair kit that puts whatever slime in your tire to plug the hole, which yeah I do NOT recommend.
    Link to Amazon is not working but go there and search for "Slime 40051"
  2. BiomedO1
    BiomedO1 Senior Member
    4,598
    2,412
    Left Coast
    WoW, I was a bit peeved, I had to spend $70 for mine - all in. But I don't have a nice place to store it in the car.
    I toss it in the hatch and strap it down on road trips. Tossed a tire chock, gloves, 2x6, chemical flares, and a couple of trash bags in with the jack, so I should be all set. The 2x6 is used as a jack base, If you need to change on dirt or soft shoulder.
    GcinFl likes this.
  3. Prodigyplace
    12,712
    11,848
    Central Virginia
    I have one of those in my car too. So far, I have only used it when topping up the tires once a year.
  4. GcinFl
    GcinFl Junior Member
    47
    23
    2024 Prius
    I bought a jack and tool set for $40 at a salvage yard. Since the jack in my 2020 Mazda CX5 worked perfectly on the Prius that's what I shopped. It wasn't too hard to find.
    #24 GcinFl, Dec 12, 2024
  5. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    AAA isn't always available either. My brother once broke down in the middle of nowhere on a major US highway and they showed up 3 days later in the middle of sub-zero weather winter. In the meanwhile, we went all the way out there, about an hour and a half in good weather, and got him and brought him home so he wouldn't die from hypothermia.
  6. Templeton
    Templeton Active Member
    371
    132
    usa
    2024 Prius Prime
    SE
    With the help of folks on here, l was able to order a toyota jack, jack crank bar, and lug nut wrench from a toyota parts place for just $67. And l got the bare (16") rim in the same order for just $54. All with free shipping too. I will have to get a "donut" tire for the rim, but those are typically under $100. So it is possible to get all this for a somewhat reasonable price (but not free with the car of course).
    My gen5 phev won't fit any of this under the rear cargo floor, but l will definitely be taking the kit on any trips out of the local area. With apologies to dirty Harry, sure, l feel lucky, but not that lucky.
    #26 Templeton, Dec 12, 2024
  7. Winston Smith
    Winston Smith Active Member
    476
    339
    OH
    2024 Prius
    LE AWD-e
    I have an AWD; this also comes with some limitation on how the trunk space is used.
    I'm thinking that a full sized spare in the rear driver's side seat all the time will be my solution. I don't want to put anything in the rear footwell on that side and have it block the battery vent.
    I suppose one might see this as an opportunity. I've changed wheels roadside with the car manufacturer's tools. Keeping a breaker bar and socket wouldn't take a lot of room, but would make a change a lot more easy.
    #27 Winston Smith, Dec 13, 2024
  8. Templeton
    371
    132
    usa
    2024 Prius Prime
    SE
    This is interesting, on the gen5 phev (SE trim), there is not any vent there. I just looked.
    You have a vent there? Do you have a gen5 hybrid?
  9. flarecde
    flarecde Member
    59
    68
    NY
    2023 Prius
    Limited AWD-e
    I can double check, but pretty sure my 2023 non-Prime has a vent on the side of the driver site rear seat. Noticed it the other day loading groceries.
  10. Winston Smith
    476
    339
    OH
    2024 Prius
    LE AWD-e
    I believe I do, but mine is not a phev, but a plain vanilla LE-AWD. If memory serves, there is a vent and filter there and one can damage the little battery over time by blocking the vent.
  11. BiomedO1
    4,598
    2,412
    Left Coast
    My old Prius C had the traction battery intake vent there too. I just avoided placing anything that may get sucked into it and clog it. All grocery bags went into the passenger side rear seat well or on top of the seat and strapped in.
  12. Hammersmith
    Hammersmith Senior Member
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Gen5 HEV cools the HV battery with cabin air, so there's a vent(and filter that needs to be cleaned periodically) under the left rear seat.
    Gen5 PHEV cools the HV battery with the HVAC heat pump system, so there's no vent.
    GeoJ, Templeton and Isaac Zachary like this.
  13. Mendel Leisk
    42,347
    With Gen 3 the seatbelt shoulder strap (when not in use) is right at the side of the hybrid battery vent, sometimes partially blocking it.
  14. rkalbo
    rkalbo 2024 XLE
    85
    Huntingburg,IN 47542
    2023 Prius Prime
    GcinFl likes this.
  15. MidCow3
    MidCow3 New Member
    2023 Prius
    I added a spare tire to Gen5 LE with no problem
  16. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    All the years I've carried never got it out cept working on car for something else .usually quicker to plug on car and keep going. Or it has been . I've also got electric gun . Never charged since first put in trunk . Thot I mite help someone else . Welp..
  17. Templeton
    371
    132
    usa
    2024 Prius Prime
    SE
    What is an electric gun?
  18. ETC(SS)
    7,555
    Taser? ;)
    NOTE!!!!
    CHECK local laws if this is the case!!
    @plugs.....The last time I had a flat (company vehicle) I used a plug kit and it was MUCH MUCH easier and faster and safer than jacking up the car and putting on a spare.
    HOWEVER (comma!)
    You still need a spare - because: life happens and not all holes are the same, nor can they all be plugged.
    This is the OTHER reason that the can of gloppy goop in the trunks of many cars isn't even as useful as an escape trunk on a submarine - because occasionally the latter DOES have 'off label' uses.
  19. Tombukt2
    13,861
    2,519
    Durham NC
    The thing you pull the trigger on and blast the lug nut off of the wheel so you don't have to turn manual wrenches makes a funny noise in the bolt falls off or the nut falls off. Like what a garage uses except with no air hose a battery
  20. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    When I bought my Gen 3, the dealer said it had run-flats, but it didn't. Probably stolen by someone who worked there I assume. Anyhow, I was concerned about the lack of a spare tire at first, but in the entire 10 years I drove it, I never had a flat. I had roadside assistance anyway, and I have no intention of changing a flat by myself.
