No speedometer display 2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bbiinc1, Oct 1, 2020.
  1. bbiinc1
    bbiinc1 Junior Member
    US
    2007 with 291k miles on the clock. Intermittently loses the heads up display on the dash. Killing the 12v for about 5 seconds resets it. Sometimes it will start working all by itself.
    Seems to do it more when fuel level is below 50%
    Any ideas? I have installed a battery switch on the ground wire to speed up the reset process.
    Thanks Steve
    SM-G955U ?
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    You can DIY and replace the failing capacitors, or buy one that has the 299k odometer limit fix, the capacitors replaced, your current mileage programmed, and includes a lifetime warranty at : Prius Speedometer Replacement
    The ground switch fix, or other tricks can last for some time (or not), and may leave you stranded with a 'no start' situation.
