No Start After Engine Replaced...Car Sat Idle For 6 Months Or So
Discussion in 'Gen 3 Prius Main Forum' started by donzoh1, Mar 12, 2020.
  1. donzoh1
    donzoh1 Active Member
    441
    153
    Lenexa, KS
    I just installed a junk yard motor into a Gen 3 Prius. While working on it, I removed the Hybrid Battery Safety Plug and disconnected the 12v negative battery terminal lead. When I finished, the 12v battery was below 6 volts so I had to jump and recharge it. Now, accessories and lights come on but the message about Hybrid Battery and Find a Safe Place to Park comes up. The previous motor failed when a connecting rod broke and I believe other systems were operating correctly. The internal combustion motor was the only part of the power train replaced but I have the rest of the power train from the donor car.
    I'm wondering whether the hybrid battery could be without enough charge at this point and how to fix that if that is the problem.
    51,157
    did you do all three steps to secure the orange safety plug?
    do you have tech stream or dr prius?
    Raytheeagle likes this.
  3. donzoh1
    441
    153
    Lenexa, KS
    i don't know all the steps to replace the safety plug. i don't have tech stream or dr prius
    51,157
    you can find it on youtube, a lot of people never complete the third step, it's counterintuitive
  5. donzoh1
    441
    153
    Lenexa, KS
    i will look that up. thanks.
  6. donzoh1
    441
    153
    Lenexa, KS
  7. donzoh1
    441
    153
    Lenexa, KS
    that was exactly it. runs like a sewing machine!
  8. donzoh1
    441
    153
    Lenexa, KS
  9. donzoh1
    441
    153
    Lenexa, KS
    although it runs well, it still has the check hybrid battery message...
  10. bisco
    51,157
    can't do much with that until you read the codes
  11. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Why on earth would you disconnect the negative 12V and not the positive? That way you always keep a 12V potential on your car and when you ground anything there will be a current flowing.
    Most likely the reason why the battery was below 6V when you reconnected it.
  12. Prodigyplace
    12,407
    11,682
    Central Virginia
    How would current flow to an unconnected battery terminal? Safety says you always disconnect the negative first and connect it last. That avoids fireworks if you accidentally touch the positive wire to the chassis.
    The 12 volt battery definitely needs replacing. You can get unusual computer codes with a weak one.
  13. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Make sure you slide handle to safety plug to right after you cantilever it to left.
  14. donzoh1
    441
    153
    Lenexa, KS
  15. donzoh1
    441
    153
    Lenexa, KS
  16. donzoh1
    441
    153
    Lenexa, KS
    Are you serious????
    kc5dlo likes this.
  17. donzoh1
    441
    153
    Lenexa, KS
    Your suggestion is dangerous from a safety perspective and has nothing to do with the battery condition after being disconnected 6 months. In any negative ground system, the negative should always be disconnected when doing major maintenance.
    Prodigyplace likes this.
  18. Maarten28
    415
    224
    Netherlands
    What suggestion did I make that was dangerous?
  19. onabuc
    onabuc Junior Member
    loa angeles
    You need to reprogram the computer...after disconnecting the hybrid batery you need to do that again....i did replace the engine on my 2013 prius and had to do it itcwont start again unless you do it.
  20. donzoh1
    441
    153
    Lenexa, KS
    I disconnected the 12v battery again and reconnected. It still had the code when I started it again but after several short drives, it cleared up. Now, it runs fine with no visible trouble codes so I don't know whether it is permanently fixed. I'm thinking it is.
