No start, battery dead?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Marye, Feb 16, 2021.
  1. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Which it does.
    Why would you buy one?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    RE: Trickle charger
    Did I say that I would buy one ?
    I would never get one nor recommend it to anyone else.
    But some people don't know the difference......and some use the term incorrectly when making a recommendation.......and some people just look for the cheapest thing possible without paying much attention to details.
  3. Marye
    Marye New Member
    Lexington, KY
    I see what you're saying. I'll read the instructions, it's a "smart charger", so I *believe* it should act the way you're saying (charging to a healthy level and then keeping it at that level), but better safe than sorry. An update to anyone that provided advice, I finally gave up and towed it to a Toyota mechanic. We'll see what they say. Thank you to everyone, I appreciate the suggestions. Unfortunately, I'm not a very capable DIY-er and just wasn't comfortable attempting more troubleshooting. It's hard for me to believe that it could just be screwed when it had been driving ok for the most part, but I've learned that in my case, if I'm going to keep this Prius, I need to learn a LOT more about them, and take it in for regular maintenance at a qualified shop. Unfortunately, I live in central KY and the nearest hybrid-only shop is about 50 miles away. I'm hoping that this isn't the end of my Prius though, I love her.
    Ok .... I'm not a Prius know-it-all here, but uh, they .. do not have alternators, correct? No need for one, since the HV battery charges the aux battery. Can someone else confirm? This is one thing I've gotten from gleaning various threads here. Also there is no physical starter like a regular car, again, no need for it, software starts the car. Unless I'm dumber than I realize and have misunderstood the stuff I've read, which is very possible.
    I kind of regret even mentioning battery chargers, maintainers, etc with the acrimonious replies here, lol. Yikes
    This is what I bought, and if it isn't the correct item to charge and maintain the battery, I'm not super worried, I'll return it and suggestions are appreciated. Should've paid more attention to what it actually is and does. Here's the link to amazon.
    It's a "Batteryminder 1510, 12v / 1.5 amp charger, maintainer and desulfator". Hmm. Maybe it isn't one of those "smart" ones. Well. At any rate, no big deal, if it isn't a good one to use, I'll return it and pay a little extra for one of those that other prius people have been using, I know there's a thread somewhere on them.
    #23 Marye, Feb 27, 2021
  4. Frank1234
    Frank1234 Member
    187
    83
    Indianapolis
    Let me know if interested in fixing the water leak I know exactly how to fix real easy!
  5. dolj
    dolj Senior Member
    8,648
    4,400
    Wellington, New Zealand
    It should be ok. Being 1.5 Amps rather than 4 Amps charging rate it will just take longer to charge up an empty battery. If you use it on a regular basis it shouldn't be a problem as your battery should always be at the top end of the State of Charge (SoC) range.
    I see it has a "pigtail" that you (or a friend or family member) can permanently attach to the battery terminals. You feed the other end of the pigtail up through the plastic cover. This allows a quick and safe quick connection to make charging an easy and simple process.
    Good luck with everything.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    YES it is a good choice.
    Just don't call it a "trickle" charger.......because it isn't.
  7. Marye
    Marye New Member
    Lexington, KY
    Ah yeah, sorry, I wasn't using the correct term. Duly noted. So an update today, they seem to believe something is causing the 12v battery to drain? They're still researching, they say ... Maybe I should see if this is something other people have come across. I'm worried this is going to be a real pain in the nice person to figure out
  8. Marye
    Marye New Member
    Lexington, KY
    And I just discovered the board censors my profanity automatically, that's neat I'll say I'm worried this is going to be a real pain in the keester to figure out.
    dolj likes this.
  9. Marye
    Marye New Member
    Lexington, KY
    Update on my own update: hopefully I have a good lead for what could be wrong. Another PC user mentioned the black box next to the battery, apparently the backup power supply for the brakes. This box has 28 capacitors, and when one fails, they say, it can drain the 12v very quickly. This, or perhaps the driver side courtesy light, but for my scenario I'm leaning towards hoping it's that's box. They're maybe $30 or $40 on Amazon/ebay. I mentioned this to the stumped mechanics, I'm not sure if they can check this or if I'll just need to buy one, stick it in and see what happens.
    If that doesn't work, I feel like I'm going to be getting very friendly with a multimeter and fuses, because that's probably where I'd be headed, pulling out fuses one by one (making sure to pay attention to where the heck I took the fuse from, haha). Which isn't terribly difficult, just tedious.
    I'm almost convinced I'm a pessimistic little girl and that maybe she isn't dead and this will be more time-consuming, but less expensive, than I originally thought. I dare to be hopeful now maybe soon I'll have a happy update.
  10. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Correct and correct.
    Marye likes this.
  11. Marye
    Marye New Member
    Lexington, KY
    Aha. Hahahahaha. Well, nope... The mechanic just called. My ******* busbars on the HV battery are corroded, they say. I know there's a method of cleaning them (no way I can do this), or even replacing them. Quoted me $3,300 for replacing the HV battery. Is this what a HV battery failure looks like? I'm sure they're trying to upsell me. Literally 2 seconds after I made the optimistic post, they call and tell me this. Did I mention how terrible my luck with cars is. Gahhhhhh. I can't afford this
  12. Frank1234
    Frank1234 Member
    187
    83
    Indianapolis
    #32 Frank1234, Mar 2, 2021
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    No doubt. What almost NO "mechanics" realize is that battery itself can develop defects that will cause it to discharge ITSELF, even when not connected to anything.
    And it appears that some don't even know how to check if it is charging while the car is running.
    SIGH.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    That might very well be true but it will NOT cause your 12 V battery to go dead.
    kenoarto likes this.
  15. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Unless the 'stumped mechanics' removed the HV battery cover (doubtful), there is no real way for them to tell if the busbars are corroded (some codes/DTCs can point in that direction), and many older prius do have corrosion, yet still function perfectly fine (until they don't). Was the rear of your vehicle disassembled to gain access to the HV battery, like in this simple step by step guide : 2004 – 2009 Toyota Prius Plug-and-Play Car Harness Installation Instructions | Hybrid Automotive
    There is, and likely that won't solve the current issue. But knowing the OBD2 codes (DTCs) will set you in the right direction. Without sounding like an optimist, and from your willingness to chase down 12v parasitic drains and all, you've got this. Just wish there was a way to go back in time and lay out a concrete plan for you to follow, we could've saved some anguish here.
    3300 is a bit steep for a new OEM battery from the dealer, but most of the local dealers in your area (link below) are asking for that much at the retail level for just the battery pack without installation. Assuming your mechanic has a wholesale account with the dealership, they might be able to get 20%+ discount. Which given labor costs for 'stumped mechanics' these days sounds about right. They would pay 2500 (or whatever) for the battery, and charge you 3300 installed, the job generally takes two to four hours, depending on skill and if you clean the HV battery fan (always recommended). This assumes they were planning to install a NEW pack from the dealership (don't fall for some random used/rebuilt/refurbished HV battery).
    Working off this list of toyota dealerships, closest to farthest :
    3165 retail at
    G951047031 - Toyota Battery assembly, hv supply. Electrical, wiring, cable | Frankfort Toyota, Frankfort KY
    2693 retail at
    G951047031 - Toyota Battery assembly, hv supply. Electrical, wiring, cable | Joseph Airport Toyota, Vandalia OH
    1773 retail at
    G951047031 - Toyota Battery assembly, hv supply. Electrical, wiring, cable | Bommarito Toyota, Hazelwood MO
    Then there is the core charge of 1350, and of course the installation (not that difficult for some).
    If the new OEM pack (or the $1600 http://newpriusbatteries.com/ ) isn't in the budget, then find a verifiable (by checking the serials) low mileage wreck, or a quality rebuild from a known source (not many out there, but we can suggest), or just DIY.
    It can look like many different things, for stumped mechanics it may look like an open purse or wallet. Likely these gentlemen have a quality scanner, and after a few seconds of scanning, the device spit out some OBD2 codes (DTCs) that could include DTC P3000, DTC P30xx, and possibly P0AA6 (ground fault), which would point towards a failed/failing HV battery. Hopefully they didn't charge you for this simple service, and if they did you should request a written invoice/estimate for the suggested repair that includes the above scanned codes (please post them here if this is the situation).
    Normally it isn't a good idea to clear the OBD2 codes before having first scanned and recorded them, but this time its different.
    You can do a simple test for a potential ground fault DTC (P0AA6) by first clearing the code(s), either by using an OBD2 scanner or by disconnecting the 12v supply at the battery (all three plugs) to clear the codes (DTCs), then wait a couple of minutes and reconnect the plugs again. Now attempt to 'ready' (or start) the vehicle, the first attempt will produce a beautiful array of warning lights on the dash (don't fret), now power down the vehicle as normal, and if your second attempt starts or makes the vehicle go 'ready', and then after shutting it off refuses to start again, then you know you have a 'ground fault',
    If the above test didn't work, now would be a great time to buy a hybrid compatible OBD2 scanner (unless stumped mechanics are in your future), many DIYers like the 'mini-vci' cable and techstream (dealer technician software) installed on a windows device. Others get by with using an OBD2 bluetooth adapter and an App like Dr Prius or Hybrid Assistant installed on a bluetooth device, learn more about compatible bluetooth adapters : Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Once you've retrieved the stored OBD2 codes (DTCs) from the ECUs (computers) post them here for additional guidance.
    Not a huge upsell in the scheme of things, most mechanics and dealerships won't even think of repairing the HV battery, only replacement. And given your nearby local dealerships extreme retail price point for a new battery, it all makes sense (mostly). But without knowing the OBD2 codes (DTCs), it would be difficult at best to say if the mechanics are or are not at this point.
    All is not lost (yet), *we* can get this sorted out.
    Raytheeagle and Marye like this.
  16. Marye
    Marye New Member
    Lexington, KY
    Guy, thank you very much for your suggestions. As soon as they mentioned a fault code I should've asked what it is. I believe I may be on the hook for $100 diagnostic fee, but I may try to see if they'll gimme a break. I'll definitely get the code (s) and post em here. My gut feeling was, well maybe they just did a generic toyota diag and as soon as something could give them a halfway justified reason to say it's the HV battery, that maybe that's what they did, given that it took them several days to reach this conclusion. Thank you very much, and I'll be back with more info. I'm going to try to not be all doom and gloom just yet! Lots of people on here are extremely knowledgeable, more so than these generic toyota mechs. Update will be coming soon!
  17. Marye
    Marye New Member
    Lexington, KY
    The code they're giving me is PA006, I believe. I'm nervous to find out what that code points to.
  18. Marye
    Marye New Member
    Lexington, KY
    Sorry. P0AA6.
  19. ChapmanF
    19,033
    P0AA6 doesn't have to be horrible. SFO gave some information up in #35 on how to narrow down where the leakage is. Depending on where it is, some cases might be correctable without a big parts expense. Others might not, but that's what needs to be found out.
    Marye likes this.
  20. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    DTC P0AA6 has three (3) related subcodes (INFs) that can help pinpoint the issue, the most extreme failure being in the transaxle assembly (have you ever changed the transmission fluid?).
    Most of time DTC P0AA6 will be a leaking module in the HV battery assembly, notice the related INFs (subcodes) for DTC P0AA6 in the image below. Some DTCs have related INFs, knowing the INF(s) may help troubleshoot an issue faster.
    If you do the above posted (and now quoted below) test you should be able to determine if the mechanics diagnosis is correct without using a hybrid compatible OBD2 device. Of course there could be additional codes that may point to other issues as well, and having a suitable (compatible) OBD2 code reader/scanner in your possession can help take much of the guess work out of the equation, and won't cost 100 each time.
    If the above test starts the vehicle (by resetting the 12v), it may be in your best interest to pay whatever (100 or less) and drive home very gently. And if in the future you need their services, for this vehicle or another then you might be good to go.
    Once you turn it off, the vehicle may not start again even after disconnecting the 12v or clearing the codes (DTCs), or it may start, and why pay for a tow if you don't have to. So best not to turn it off until you have a proper place to park it again.
