no start or turn over
Discussion in 'Generation 1 Prius Discussion' started by hometownautomotive, Sep 3, 2018.
  1. hometownautomotive
    hometownautomotive Junior Member
    22
    port alberni bc
    2001 Toyota prius has new 12 volt battery and main battery good it came out of a running prius car sat for a number of years no codes in vehicle turn key doesn't do anything no crank wondering if fuel pump is shot has fresh fuel in it
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    More likely high voltage hybrid battery is too low to crank over the engine for startup.
    If that is the case then you will need to build or a buy a high voltage charger. Or open up the pack and charge sections of the pack with some other charger until you get the state of charge high enough.
    You may want to purchase a version of Toyota's Techstream software and hook it up to a Windows XP laptop so you can see live data from the car.
    You could get a voltmeter and read the voltage of the HV battery and report back here.
    Be very careful about trying to start the Prius too many times. You basically have less than five attempts to get the car running. More than that and the HV battery will be driven to low to start the car.
    Before you turn the key you should do afew things first to give yourself the best odds of starting.
    Sop up oil that has collected on the intake under the throttle body.
    Clean the throttle body
    Clean the MAF sensor
    Make sure fuel pump works
    Squirt some starter fluid down the intake and immediately jump in the car and turn the key and then hop back out to continue putting fluid down the carb to keep it running until car can take over itself.
    Feel free to call me me during weekday work hours to discuss.
    #2 ericbecky, Sep 3, 2018
  3. ChapmanF
    19,041
    Anything light up on the dash when you turn the key to ON?
    Any clicking sounds from behind the back seat when you turn the key to START?
    I love autocorrect, and now I'll be looking for as many opportunities as possible to say viltmetvo.
    Viltmetvo viltmetvo viltmetvo.
    Wait ... how does autocorrect come up with viltmetvo?
    -Chap
  4. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Ha, ha. Who knows? I'll go fix it. Stupid autocorrect.
  5. hometownautomotive
    22
    port alberni bc
    WAS THE PARK SWITCH OUT OF ADJUSTMENT THOUGHT VEHICLE WAS IN GEAR
  6. kayodeolubowale
    kayodeolubowale Junior Member
    Please I need help with my 03 Prius. The vehicle runs and drives good. Recently I took it to a body man to change some body parts. After about 2 to 3 weeks the vehicle was completed, the vehicle wont start. Checked and recharged the 12v battery, still the dashboard lights came up but, wont start. Took it down to the dealer, and they said " the key is not connecting with the computer and it will cost over 1k usd to fix". I don't believe this. Please I need help. Thanks
  7. hometownautomotive
    22
    port alberni bc
    sounds like the high voltage battery is to low or the high voltage was left out by the body shop
  8. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Vanna, I'd like to buy some punctuation. . .
