No Tail Lights
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tnt4him, Oct 29, 2015.
  1. tnt4him
    tnt4him Junior Member
    53
    Beaverton Oregon
    Just discovered on my 2012 Prius C3 I have no tail lights. I checked the fuses but there was not one that said tail lights or parking lights. Check all the 10amp fuses anyway and they all looked good. I did avionics in the Navy so this should be an easy problem to fix if I had the wiring schematics. Can anyone help me find it?
    52,803
    have you checked the bulbs?
  3. JC91006
    16,935
    8,646
    brakes switch? stop lamp fuse
  4. PriusInParadise
    180
    91
    Hawaii
    The 10A Tail fuse is in the instrument panel fuse block, almost directly above the foot rest.
    You'll have to look upward, from the driver's footwell.
    ftl likes this.
  5. tnt4him
    53
    Beaverton Oregon
    Thanks! That was it. A third fuse box hidden under the dash. Who would of guess?
  6. bisco
    52,803
    agreed, guessing doesn't work well in troubleshooting. unless you're a dealer charging $120. / hr. plus parts.
  7. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    A 3rd fuse box?
    One in the engine compartment.
    One above the dead pedal.
    Does the "C" have a third one? If so, where?
    (Just curious)
  8. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    There are 2 in the engine compartment, they're closest to the where the hood hinge meets the rest of the car and just below the top of the struts. The 3rd weirder fusebox is in the footwell on the drivers side.
  9. RRxing
    2,562
    1,839
    NEPA
    Thanks
    "The More You Know..."
