No takers so far
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, May 16, 2025.
Thread Status:
Not open for further replies.
  1. ETC(SS)
    7,571
    If you have a "highly variable parasitic drain" then a battery isn't going to solve the problem.....INCLUDING the 266VDC Li-Ion battery pack that you're trying to tap into!
    You NEED to find the source of your current leak.
    Usually they fall into some predictable categories, listed in order of probability:
    1. Accessory inspired wiring mod
    2. Accident - improperly repaired.
    3. Manufacturing defect.
    4. Manufacturer design flaw.
    G5s are three years old - and I'm not seeing many people complaining about having to jump dead batteries in these cars over and over again. They DO have under-sized batteries because of corporate greed - but they ARE generally sufficient to stay in service for 3-5 years.
    You've 'likely' already engaged your local Toyota dealer about this since the car is only 2 years old - and even Toyota's sad warranty will cover a wiring issue in a vehicle less than two years old - unless you've already boltered through the mileage limit...
    You can find some kid to manufacture a DC-DC circuit to trickle charge your AUX (13.5VDC) battery from your Traction (266vdc)...easy peasy!
    HOWEVER (comma!!!!)
    Such a modification would immediately and justifiably void your vehicle's warranty, AND for a pretty good reason!!!!!
    You've PROVEN yourself that if you have a "highly variable parasitic drain" that draining TWO batteries with the "highly variable parasitic drain" is MUCH MORE than twice as dumb as ONLY draining the 13.5VDC battery.
    Advice:
    1. Fix your car.
    2. Get a jump pack, and move on with your life.
    Brian1954 and Rebound like this.
    52,878
    lots of people have had 12 volt problems with the g5, and there are many threads here
  3. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    My car can't be parked overnight anymore without needing a boost, (If I forget to plug in the battery maintainer that is). The battery voltage in the morning is around 5 or 6 volts. It's a shame they didn't devise some way for this lower voltage to activate the DC-DC converter. As it is, the car is dead if it's below 11.5.
  4. ETC(SS)
    7,571
    For those not wanting to dumpster-dive into that thread - Priuses have two batteries, one being a 12v 'aux' battery and the other being the traction battery with a much larger capacity and nominal voltage.
    GENERALLY speaking you do not cross connect these for pretty obvious reasons - especially in a car that becomes a 3200# piece of lawn art if the traction battery dies.
    In short...(pun nearly unintended) you can safely jump start a Prius with a device that fits in your pocket.
    If the traction battery is flatlined, probably the best and DEFINATELY the safest outcome will require a tow truck.
  5. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I have opined in previous threads about what I consider a design flaw in the Prius. When the 12V battery falls below a certain threshold voltage (11.5 V in my case) the car is unstartable and requires either a boost or a dealer service call (some people do opt for the service call). The battery can fall to below the threshold in as little as 2 hours in my experience. The dealer replaced the battery to no effect.
    Why couldn't there be a way to engage the DC-DC converter in such circumstances? It does not seem like an insurmountable engineering problem to me.
  6. Tideland Prius
    16,683
    What? No it's not lol. We just created it to be less supervised so we don't have to deal with politics on the main forum.
  7. bisco
    52,878
    but not for people without electric coolers, correct?
  8. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I've isolated the electric cooler from the 12V system of the car. The problems I've encountered have nothing to do with that.
    You don't have to read my posts, but if you do, I'd appreciate better comprehension.
  9. bisco
    52,878
    so you're the last one with 12 volt problems in gen 5?
  10. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    He is the first, the only one, and probably the last one with the particular problem he is having.
  11. Mendel Leisk
    42,362
    Always-on security systems cause similar problems. Basic tenet: thinking of using the 12 volt for anything extra? Don't.
  12. Gokhan
    6,715
    2,672
    Paramount CA
    Background: He installed an auxiliary 12-V LFP battery to run a cooler and connected it to the primary 12-V flooded-cell lead–acid battery using a battery insulator. Originally, the LFP battery was draining. To remedy that situation, he later got a new battery isolator with adjustable voltages and set the cutoff/cut-in voltages to the point that now, the car no longer charges the primary 12-V lead–acid battery. It drains everyday as a result.
    No one else has the problem you are having. It is a problem you created yourself. Then, you blame Toyota and everyone else for your problem.
    You bought one of the most advanced/sophisticated cars in the world, and you redneck-engineered it with minimal understanding of electronics if any. It is a bad combination. Things will progressively get worse. Once the warranty expires, you will be in trouble.
    Even if Toyota did what you asked for, it still wouldn’t work because the car’s 12-V battery management system (BMS) doesn’t/can’t realize that the 12-V battery is constantly draining with the way you adjusted your battery isolator.
    As I said a long time ago, these battery isolators are meant to be used with cars with dumb alternator charging systems that always keep the charging voltage at 14.3 V, and they will not work with cars with a 12-V battery management system (BMS), like the Gen 4/Gen 5 Prius HEV/PHEV:
    VGate Battery Assistant battery monitor | Page 2 | PriusChat
    Now, your second 12-V battery, which you got under warranty, is also ruined thanks to the constant full drains and you need a third one. I wonder what the dealer will think when they see your battery-isolator setup.
    Brian1954 likes this.
  13. ETC(SS)
    7,571
    Man....
    Glad I bought a GMC......
  14. Gokhan
    6,715
    2,672
    Paramount CA
    It is the same. GM also uses a 12-V battery management system (BMS). If you want a car with a dumb alternator/IC regulator charging system that always keeps the charging voltage at 14.3 V, you need to buy an old car.
    https://www.silveradosierra.com/threads/what-was-gm-thinking.744094/
  15. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I feel like I'm being scolded for something I did wrong. But I didn't cause the rapid parasitic drain, that occurs independently from my mod consisting of an auxiliary battery to run my electric cooler.
    I do wish you'd be more accurate in your assessments of my work.
  16. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It doesn't matter if I'm the only one, but from what I've read, it happens to a lot of other Gen 5 owners.
    I offer my own experiences to assist others if possible.
  17. PTS
    PTS Member
    100
    50
    Austin, Texas
    2013 Prius v wagon
    As long as a custom solution is needed
    Antigravity Lithium battery with Restart (built in jump start with a remote)
  18. ETC(SS)
    7,571
    My current 4 GMCs are an 06, 12, 20, and 23.
    My three before that were also GMC.'s
    The last two are still using their OEM batteries and I've only had a battery fail in service on the 2012 - after 6 or 7 years.
    Since I always carry jump packs I didn't require any assistance with getting it replaced with the battery that's still installed.
    I only have 150,000 miles of stick time (more or less) in Priuses because my company had a dalliance with hybrids in the mid 2020s that they now have gotten over.
  19. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I carry a jump starter in my car. It is not a solution. If not for this design flaw, the car could be parked for several days without becoming unstartable due to a flat battery.
  20. bisco
    52,878
    there were a lot of others, but they all seem solved by a software update or new battery.
Thread Status:
