No takers so far
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, May 16, 2025.
Thread Status:
Not open for further replies.
  1. bisco
    52,877
    but a little humility goes a long way
  2. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I don't think so.
  3. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    All I've tried to do is be as clear as I possibly can,
    but some are intent to insult me in any way possible.
    But I am the problem?
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    If it drains it in two hours a high school kid with a meter could find out what device was sucking up amps.
    Something is seriously wrong with the story we are hearing.
    By the way why are we hearing this months long rant? Toyota Corporate has a team of customer support people to step in when a legitimate issue is presented to them.
    On top of that, there are lemon laws that would refund the purchase if even half of this story actually happened.
    One has to wonder how important "drinks" are to the situation.
    Brian1954 likes this.
  5. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I bought my car in January 2024, at least 6 months before there were any "drinks" in the car. I have had problems with battery drain since nearly the first week I owned it. I have pursued every route I can go with Toyota. They even replaced the battery, but they could not explain the cause of the problem. What can I be expected to do? I have been extremely clear on the facts, and I can't answer to your incomprehension of them.
    I see nothing reasonable in your post; it seems like nothing more than a bad-tempered rant.
  6. frodoz737
    frodoz737 Top Wrench
    4,808
    2,562
    33
    The answer you are looking for is not on this forum...at this time. We all understand your frustration, but playing the soldier and/or victim "here" will solve nothing at this point.
    So I'll take one more stab at this. Did your Dealership/s Service Department/s duplicate the standard use where you stated the battery depletes to the level of needing a jump?
    #106 frodoz737, Aug 29, 2025
  7. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    He has messed up the cut-in and cut-out voltages of his battery isolator, and his cooler is constantly draining his primary battery now.
    VGate Battery Assistant battery monitor | Page 2 | PriusChat
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    One of two things is true:
    1) You installed a device in your car which is causing a parasitic draw
    2) You need a new 12V battery
    Gokhan and Brian1954 like this.
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Neither of those things are true. It would be obvious to anyone who has actually read my posts.
    What do you stand to gain by this nonsense?
  10. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
  11. Rebound
    3,996
    2,645
    Portland, OR
    In fifteen years of Gen III Prius ownership, my battery has never worn down. I replaced [email protected] battery once only, after ten years, just as preventative maintenance.
    So, yeah, your car has a bad battery or a parasitic drain and it’s probably because you messed something up, because that’s the cause of 99% of parasitic drains.
  12. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I owned a Gen 3 Prius for 10 years, I had a 50 mA constant draw that drained my battery in about 8-10 days. If I drove it at least once a week, no problem. Longer than that, I needed a boost or to use a maintainer.
    You seem to be claiming that I am lying, simply because you don't believe it. Not very logical. You are also assuming that I messed something up. Nothing in that makes sense, if you care to look at the facts. If the game is to get me to repeat the same thing over and over, you win.
  13. bisco
    52,877
    it was probably the drinks cooler in your gen 3. we went south for 3 months every winter, leaving our gen 3 in the garage, and it always started when we got back, until it didn't
  14. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    How do you explain how my battery was going dead six months before I used the cooler?
    This has got to be the 20th time I've explained this.
    This is the Gen 5 forum BTW.
  15. bisco
    52,877
    you brought up your gen 3, i'm just replying. i'll give you some thoughts about why it was draining, if you want to ask in the pip forum.
  16. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Maybe hold your comments until you can actually understand what you're responding to.
  17. bisco
    52,877
    maybe, but where's the fun in that?
    #117 bisco, Aug 29, 2025
  18. Gokhan
    6,715
    2,672
    Paramount CA
    That is exactly what it is:
    • The cooler is continuously connected to the primary battery at all times because he lowered the cut-in voltage from 13.3 V to 12.1 V, resulting in a tens of amperes of parasitic drain.
    • The current primary battery is highly sulfated and no good anymore because of the resulting repeated full drain.
    Only he knows what he exactly did and what kind of problems he has been experiencing and at what times in the history of his car, but he had posted earlier that his battery problems had been solved and he was no longer having parasitic drains after the dealer had replaced the original battery and fixed the problem with the Toyota connected services or something like that. He then installed an auxiliary 12-V LFP battery and a cooler attached to it through a battery isolator, but the auxiliary battery would drain. However, he repeated that he was no longer having problems with his primary battery. He then said that he figured out the problem with the auxiliary battery and got an adjustable battery isolator, and he lowered the cut-in voltage to the point that now, the primary battery is connected to the cooler and drained by it at all times.
    The following is the typical battery-insulator setup with typical cut-in/cut-out voltages. The auxiliary battery is isolated from the car and only connected to the load, which is the cooler in his case, unless the charging voltage reaches 13.3 V. It is isolated again when the charging voltage falls below 12.8 V. In this way, the primary battery is not drained by the load (cooler in his case) when the car is not charging the primary battery.
    What he then did was to lower the cut-in voltage to 12.1 V, which resulted in the auxiliary battery and the load (cooler) being connected to the primary battery at all times. Now, a cooler is a huge parasitic drain.
    It also makes no sense to lower the cut-in voltage below the cut-out voltage. Chances are that when you do that, the battery isolator always connects the primary battery to the load.
    Another issue is the use of a 12-V LFP battery. A 12-V LFP battery’s voltage is about 1 V higher than that of a flooded-cell lead–acid battery for a given state of charge (SOC). Therefore, it is unlikely that an LFP battery would be compatible with the Gen 4/Gen 5 Prius HEV/PHEV 12-V battery-management system (BMS), which likes to keep the DC–DC converter voltage as low as possible. It would be even more challenging to use it as an auxiliary battery through a battery isolator because of the additional complexity of the cut-in/cut-out behavior. That explains why his original battery-isolator setup resulted in the drain of the LFP battery. Then, he went ahead and entirely messed up the cut-in voltage, and now the auxiliary battery and load (cooler) are continuously connected to the car and severely draining its battery.
  19. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Of course none of this has anything to do with the 12V battery drain. It happened at least six months before any of these accessories were installed.
    Of course, I have explained this many times, but I guess you think it helps your case to remain totally obtuse to these facts. I'd ignore your nonsense, but I'm actually trying to help you.
  20. Brian1954
    Brian1954 Senior Member
    2,692
    1,076
    South Central PA, USA
    So, are you saying that you presently do not have the problem with your 12v battery draining?
    It sounds to me like you had the original problem with the 12v battery right after you bought the car and the battery was replaced by the dealership. Now you have a separate 12v battery drain problem, which is not related to the first problem.
    #120 Brian1954, Aug 29, 2025
    Gokhan likes this.
Thread Status:
