No TPMS? Canadian version
Discussion in 'Prius c Accessories and Modifications' started by FireFire, Nov 23, 2015.
  1. FireFire
    FireFire Member
    101
    Ontario, Canada
    First I found Canadian version doesn't have oil change indicate light.
    I changed winter tire last weekend and notice the TPMS didn't turn on.... Looks like that function has been cut by Toyota Canada.
    Oh well......:mad::mad::mad:
  2. Tideland Prius
    16,665
    Where was your car parked?
    Where were your all-season tyres stored?
  3. FireFire
    FireFire Member
    101
    Ontario, Canada
    I was driving it to work yesterday and no tpms warning light at all for a whole day. Unless they are using the same "old" tpms system like my 2006 sienna. Otherwise the light should be on already. Right?
  4. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    US prius c doesn't have an oil change indicator light, no Toyota's do. They have a service engine soon or maintenance soon message. On Prius C it's a message that pops up on the main info screen.
  5. FireFire
    FireFire Member
    101
    Ontario, Canada
    The tpms light finally came up this morning. Don't know why it takes that long.
    The serivce soon message does not exist with Canadian version which confirmed by Toyota Canada.
  6. Mendel Leisk
    42,240
    True dat.
    Honda's got a cool service reminder: not just counting kilometers, not sure what all it monitors. I'd guess km's, but also number of starts, mean coolant temp, rpm, because it varies depending on your driving style.
    The reminder counts down by %, and once it gets to 15% remaining it also displays a code, which when you reference in the owners manual tells you exactly what needs doing at the next service.
    That in itself is cool, and goes a long way towards stopping discussions with larcenous service writers.
  7. Tideland Prius
    16,665
    Well you didn't answer my question but post #5 pretty much confirms it.
    The TPMS is connected wirelessly. If your AS tyres are stored nearby, it registers it when you start the car and keeps it. I can go to work and return at the end of the day without the light coming on (yes!) but if I go to dinner after work, then it the light will come on at some point in the evening.
  8. FireFire
    FireFire Member
    101
    Ontario, Canada
    Yes. On my sienna, the tpms will come up pretty quick since it detect by the rim turning speed. I didn't know it will take that long to light up. I thought the tech is improving instead of going back. :)
    Thanks for your help.
  9. mertechperformance
    532
    126
    Nor-caL
    On my c the light will come on and go off if corrected quite quickly.
    It's pressure a pressure monitoring system not rotational. The rotational aspect is used with abs. The systems are not linked. You can take 4 synced up sensors and place them into a sealed chamber and fill to spec with air and the car will see all tires as being to spec. A bit of a trick folks with aftermarket wheels that won't fit the tms sensors do.
  10. FireFire
    FireFire Member
    101
    Ontario, Canada
    On the old sienna, yes. They are abs tpms. On the Prius c, it's new one.
  11. mertechperformance
    532
    126
    Nor-caL
    Ok... pressure sensor is better than abs in my book...
  12. Mendel Leisk
    42,240
    Or just ignore it.
  13. mertechperformance
    532
    126
    Nor-caL
    I'm just about to the point of taking apart the cluster to block if the bs lights that are always illuminated and are of no value. Time will tell. That tire light would drive me bananas.
  14. dborn
    dborn Junior Member
    44
    Montreal, Canada
    2015 Prius c
    On our Canadian 2015, there is TPMS. But we put on winter tires without TPMS sensors.
    At first it took over a half hour before the TPMS light started flashing for about a minute and then it stayed lit constantly.
    After a few days it only flashed for a minute and then turned off and now it doesn't turn on at all after the initial "lights check". I expect it to go back to normal once we put the summer tires back on in the spring.
  15. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Convenient/intelligent if it shuts the light off after a few days of not seeing the sensors. I don't think the US version does that, in part because of the requirement for the system and the fact that fewer of us don't change to snows every winter. The folks who do would appreciate that!
    It is likely that the system is more responsive to a low pressure signal from a communicating sensor. If it can't make contact with a sensor, it may poll for longer before tripping the light.
    mertechperformance likes this.
  16. Mendel Leisk
    42,240
    Our warning light stays on all winter with TPMS'less snow tires. But the stock tires, with TPMS sensors, are in a stack in the garage, and we park right next to them. So not sure what that proves.
  17. dborn
    dborn Junior Member
    44
    Montreal, Canada
    2015 Prius c
    Yeah, I hope it's more intelligent than broken! ;)
    The summer tires are stored on a rack about 7' off the ground at the back end of the garage. The C usually sits outside about 30' away from the tires, though a metal garage door. Even when it goes in the garage, it's never closer than 15' of the tires and the car's ignition isn't turned on for more than a few seconds while entering or exiting the garage so it probably doesn't have alot of opportunity to pair back with the sensors assuming 15' is close enough.
    I too am a bit surprised to see that the TPMS light isn't nagging the heck of out us every day! I am figuring that the logic is that since none of the sensors are visible even after many days that it figures that it's not an actual malfunction but rather a deliberate act. I guess we'll see in the spring! I guess it's not impossible that Toyota (hybrid?) cars are _that_ intelligent!
  18. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I've heard that you can get sets of TPMS sensors to use with a separate set of snow tires on rims that can clone the IDs of the sensors on your summer rims so that the TPMS still works when you swap them. Has anyone done this? Is there a particular type or model number of TPMS sensor that you need for the Prius C?
    I'm thinking of asking a tire shop to do this for me, but it would be useful to have as much info as possible in case I need to steer them in the right direction.
  19. dborn
    dborn Junior Member
    44
    Montreal, Canada
    2015 Prius c
    I've found these: http www standardbrand com en tpms oe-matching-sensors
    That was something we considered but finding a local garage that could do the actual programming of the sensors using the same codes as the OEMs proved to be too lengthy for the time we had.
    We might consider it in the future but so far, the TPMS light in the car isn't too annoying. And, we've never had a car with TPMS before and managed to survive anyway! :)
    (sorry for the obfuscated link but it gets filtered out otherwise. I'm sure you can figure it out!) :)
    #19 dborn, Nov 29, 2015
  20. Mendel Leisk
    42,240
    What I find frustrating is the concept of Tire Pressure Monitoring is a very good idea; it's the complex and expensive implementation that's the problem. Not so bad with a single set of wheels, brand new car, but with snow tires or just the passage of time, dying batteries, it becomes prohibitively expensive to maintain.
    dborn likes this.
