No voltage measured across "12V" battery after recharging
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gdowdy3, Sep 1, 2024.
  1. gdowdy3
    gdowdy3 Junior Member
    In case anybody cares how the story ended... I charged my battery for a total of about 20 hours. At that point in time, I was able to measure 12.3 V across the battery terminals, and I was able to start the car. I have since taken the car on 6 distinct trips spread over several days, and it has worked like a champ. Fingers crossed that it holds up now that I'm using the car regularly again...
    BiomedO1 and Brian1954 like this.
  2. BiomedO1
    BiomedO1 Senior Member
    2,816
    1,498
    SacTown, Ca
    That Diehard charger/maintainer only puts out 2-4 amps, which would require more than 24 hrs of constant charging for a near dead battery. The reason it takes so long to recharge is the battery terminals are still attached to the car, so the charger needs to overcome the cars maintenance current draw before putting anything into the battery. That usually takes about 0.5A away from the charging process.
    For example, sometimes I forget to hookup my fishing/camping truck for a few months and the battery goes down to 4VDC. It takes at least 12 hrs @ 6A to get the battery back to a point I can start the truck. I do have a 12A jump/boost starter, but that's really hard on a battery. Like a good BBQ, low and slow is a lot easier on a battery.
    You may want to run some wires up into the trunk area, so you can easily plug-in for maintenance charging, if you leave the car unattended for long stretches - especially if your going to plug back in that Metromile scanner.
