No voltage on the turn signal light
Discussion in 'Gen 3 Prius Technical Discussion' started by douson, Jun 1, 2019.
  1. douson
    douson Junior Member
    US
    Hello everyone. I have a Toyota Prius Four 2015. My DRL lights do not work. Right turn signal and left turn signal work. I measured the voltage on the connector. But not LED DRL lights. The white and black wire is ground. Green and yellow turning signals. Red wire I do not know, there is no voltage. How does it fix?
  2. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Check the fuse.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    Is there a DRL position on the headlight switch ?
    Do the high beams work ??
    Then......on some models, the DRLs won't light unless it is in gear (and they are turned ON, of course.)
    Any chance that your car originally came from Canada ? DRLs are not required there now.
  4. douson
    US
    @Grit i cheked the fuse, it is not broken.
    @sam spade 2 I switched the switch to auto. Still, there is no voltage on the red wire. Maybe someone has a connection diagram?
  5. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Release the parking brake, then turn engine over on engine "ready" and turn on parking lights on the headlight stalk. The w2w bulb above the highbeams (parking light), DRLs and taillight should all come on. This will provide power to the DRLs & bypass the 'auto' on stalk if the auto on headlight stalk is not working / sending power to DRLs.
    douson likes this.
  6. douson
    US
    I did as you advised. The parking brake has been released twisting to the second (pic) stop turns on the parking lights and DRLs too. I have a Toyota Prius 2015 and auto mode still does not work. Maybe Toyota has changed the scheme?
    Thank you so much @Grit
