Noise at startup regardless of temp
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by SvMi, May 21, 2015.
  1. SvMi
    SvMi New Member
    Hi all,
    I have recently noticed that my Prius C ICE engine kicks in at every start regardless of temp or battery.
    After the ICE "warmup" or whatever it is, it goes back into EV (this is all done with the car in PARK) so at this point, I have turned off the car, waited a minute and turned it back on to notice the same thing.
    With the battery gauge almost full + 80 degree weather, is this a normal thing ?
    Hopefully you can see/hear it all in this video !
    Thanks
  2. SvMi
    SvMi New Member
    no one ? :(
  3. Mendel Leisk
    41,907
    It's normal for the engine to run after startup, unless the car's completely warmed up, just shut down for a few minutes after an extended drive.
    Well, I'm speaking of a regular 3rd gen Prius, but suspect the c would behave the same.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    My C does the same thing.
  5. bisco
    52,393
    i'm not sure i understand what you're saying, can you give us more detail? how are your mpg's? that's a good determining factor of operational conditions.
  6. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Seems pretty normal to me.
  7. HeavyUser
    HeavyUser Junior Member
    30
    NY
    2014 Prius c
    Mine does the same thing, completely normal
  8. bisco
    52,393
    what is this noise at start up? is it a clatter like piston slap?
