Noise Control (Sound Vibration Damping)
Discussion in 'Gen 3 Prius Audio and Electronics' started by Gwest, Jan 13, 2010.
  1. Gwest
    Gwest Member
    97
    Redwood City
    I still have not taken any more DB numbers. The roads and the weather has not been ideal for testing. I did end up doing the Vibration block and Sound block treatment on the rear hatch back. After doing the doors I started tapping on all the panels and the rear hatch was quite noisy. The rear quarter panels are on my to do list as well. I’m so happy with how the doors worked out I decided to move up the to do date on stage 2 (The floor to next week) I ordered all the material yesterday and it should be here next week.
  2. Azimuth
    Azimuth Member
    136
    32
    Austin
    Are you able to provide links as to where to buy the materials?
  3. Gwest
    Gwest Member
    97
    Redwood City
    Cascade Audio Engineering – Sound Damping and Sound Blocking – Anything Else is a Compromise
    Ask for Paul: I have been talking with him. He knows what I have orderd.
    You will need
    1 Shop pack of the V-MAX This comes with 10 Sheets of the rubber
    and aluminum vibration block (this will do the inside of all 4 doors and the hatch with a bit left over (1 sheet)
    2 DK-1's That's the sound block material that covers the inside of the doors each kit has 4 sheet's of the "VB-2" it takes about 2 sheets to do each door.
    the DK 1 kit also includes material that you use around the speakers
  4. Gwest
    Gwest Member
    97
    Redwood City
    Ok I got some DB numbers
    These are DB numbers with ONLY the doors done (Stage 1)
    Sitting Still motor running 10 second recording's
    Before: Min 60.1 Max 63.6
    After: Min 51.2 Max 55.1
    City Driving 35 MPH 10 second recording (recorded on the same stretch of road each time)
    Before: Min 49.0 Max 84.6
    After: Min Low Max 80.7
    Freeway Driving 65 MPH 10 second recording (recorded on the same stretch of road each time)
    Before: Min Low Max 88.9
    After: Min 55.1 Max 86.1
    All recordings I’m holding the Db meter in the same location so as not to transfer road noise threw the car and into the meter. I’m holding the meter in the center of the car (just over the arm rest) about ear level.
    I don’t know why in some recordings I would get a LOW reading in the min portion of the recording. I don’t know how these numbers transfer into real world data. I’m not a sound engineer or scientist just a guy that wanted to see what I could do to make the car a bit more quite. I just took the numbers for my reference. I’m not promoting this company or this mod I’m just sharing what I’m doing, So I apologize in advance if my testing results are not “lab quality†I have done what I can to make sure the before and after tests are taken under the same conditions each time. I can tell you (stage 1) of my little project did make a difference to my ear. I didn’t need the DB to tell you the car is much more quiet. I do feel the greatest noise reduction will be in (Stage 2) the floor
    5 people like this.
  5. MikeDS
    MikeDS Member
    298
    Los Angeles
    Nice...Low just means its below the threshold the dB is set at. aka, really quiet. Your numbers look good 3dB is a lot. I'd still like more detail on how you did the inner part of the door. That looks really hard. Did you just cram your arm in the hole and get as much as you could in there?
    Thanks for all the info!!
  6. Gwest
    Gwest Member
    97
    Redwood City
    MikeD; This is the door with the door panel off.
    There is plenty of room to get to the back side of the door skin. You un-bolt that white piece of foam and then you have a pretty big place to put the material threw. Also the Speaker hole is another place you can get your hand into and threw. Even the place where the door handle is open is a place you can put your hand. So don't worry about access. You can see in the picture above the inner door panel is un treated and has nothing on it. Uuuuu I take that back there is 2 small pieces of factory sound damping material. Its a joke.
    This is the door with the inner skin that has the Vmax on it.
    This is the same opening that you see with the white foam on it but it has the V-max on it. This is the sticky material with rubber and aluminum sandwiched between it. This is the material that makes the door panel sound more dead. The rubber sticky sheet go's over the door panel and helps stop the road noise coming threw the door.
  7. topkick
    topkick Member
    166
    Oklahoma City
    GWEST did you have to drill the rivits to remove the speakers? Could you have covered the inside of the door without removing the speakers?
    Thanks, this is one job that I think I want to do:).
  8. MikeDS
    MikeDS Member
    298
    Los Angeles
    Thanks Gwest! This is so tempting...I like my Prius, but I'd love it to be more like a Lexus!
  9. Gwest
    Gwest Member
    97
    Redwood City
    Topkick: Yes you have to drill out the rivets on the speakers. It's easy then I just replaced the rivets with bolts.
    MikeD: Yea I know what your talking about. My wife has a IS 300. After rolling around in that all weekend and then jumping into the Prius was the reason I started this project. This car has so much potential to be super quiet.
  10. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    For those that have played around in the doors, I'm trying to figure out a thickness to purchase (or more likely a mix of thicknesses depending).
    The stuff can be procured at 1/8", 1/4 ', 3/8", 1/2", 3/4", 1" 1.5" etc.
    What is the thickest I could put against the outer door skin (looking for approximate)???
    TIA
  11. Gwest
    Gwest Member
    97
    Redwood City
    Sorry I don't understand your question? Are you asking what thickness material should you buy? I was un aware that you had any choice. All the stuff I have seen is all around the same thickness.
    Some material is used to stop the sheet metal like the floor or the door skin from vibrating and creating noise. This material is pretty much one thickness. The Second type of material is a Sound Blanket type of material. This material is used to either keep the noise from transfering into the car. They have sound blankets that mount under the hood or on the fire wall of the car. Im pretty sure these are the only sound dampining material that comes in diffrent thickness. The material you use on the doors and the floor are pretty much all the same thickness.
  12. rrolff
    1,610
    246
    So Cal
    The stuff comes in any thickness (for the most part) you may want Soundproofing & Noise Control Materiels Prices. As long as I'm opening the door, I want to get as thick as possible - especially behind the speakers (when the stereo is playing, it is loud outside the car).
  13. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Do you use roller to attach it to the door skin? Do you use any heat to warm up the door skin? How is the glue quality? I'm always worried it might peel later and get stuck on the glass and make a mess. Thanks.
  14. Gwest
    Gwest Member
    97
    Redwood City
    The V-block. (the stuff thats on the inside of the door skin) is Super Sticky. I don't see this stuff coming down anytime soon. When you peel off the backing Look out. It sticks to itself and anything it touches like crazy. I didnt need to roll it. I had a smooth plastic tool that would help smooth the material out.
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I've used RAAMmat (RAAMaudio) that I bought years ago to try insulating the spare tire area of my 350Z to cut down on road noise. Unfortunately, only applying it there didn't make any measurable difference (via my sound pressure meter). I can't speak to how well this would work w/a Prius.
    I didn't feel like taking apart the doors though to line them as some audio shops will do. I think putting some in there + under the carpeting should help.
  16. Gwest
    Gwest Member
    97
    Redwood City
    This is my first sound damping project so, I can’t tell you if treating the whole floor is the most effective way to get the car as quiet as you can but it makes sense. I have been told (by the people selling product) that if you don't treat or cover the entire floor the sound migrates to the area where the floor is not treated. Seems or gaps in material have to overlap or sound comes right threw that area. The spare tire area in the Prius seems to be a place where sound ends up. You only have to lift up the cover to see their is noting back their to block noise
    My material should be here soon. I’m excited to hear the change. I have a good feeling it's going to make a big difference.
    I’m guessing all the material that ends up in my car is going to add about 50 pound's to the car.
  17. synq
    synq White, black, red
    Dordrecht, The Netherlands
    Any progress on the floor?
    My Prius will arrive in a few weeks and sound proofing sounds like a mod I would like very much, considering I come from a bmw 540 touring. :)
  18. Gwest
    Gwest Member
    97
    Redwood City
    I got some material today.
    I decided to start with the trunk.
    The interior comes apart very easy in about 10 mins it looked like this
    I added the anti vibration material. This stuff is like Dyna-Matt
    This is the Road noise block material. It's a rubber mat with a foam layer. [​IMG]
    I decided to make a template out of paper and then I will lay the template on top of the rubber mat and cut it out and then glue it down. Here is the template.
    [​IMG]After the trunk is done Im gonna un bolt the traction battery and treat the underside of the traction battery floor and the passenger compartment
    4 people like this.
  19. synq
    Nice pictures, it gives a good idea of how easy this should be. How long did it take you to get the trunk done?
    I have talked to my dealer over the phone today. Since they have to get all the interior out to put in the dealer options that might be the right time to put this insulation in. The dealer has agreed to at least discuss it with me. How nice is that. :)
  20. Gwest
    Gwest Member
    97
    Redwood City
    SYNG: The interior comes apart super fast. Im guessing I could take EVERYTHING out of the car in 1 Hr. Im not done with the trunk so Im guessing it would take about 4 hrs to take apart and install 2 layers of sound damping. If they are only doing 1 layer of sound damping then 3 hrs.
    Anybody have any tip's for removing the traction battery. I dont need or want to disconnect it. Just move it for a few mins and do the flooor under the battery and then put it back.
