Noise from battery fan
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by bobisshortforbobert, Aug 24, 2019.
  1. bobisshortforbobert
    bobisshortforbobert Junior Member
    Pakistan
    2014 Aqua
    I couldn't find a thread on this.
    My battery fan has started making these pinging-type sounds every time the car hits bumps. It sometimes even happens when I brake. I have been able to replicate the sound, and it is 100% the battery fan, as you can hear in the following video clip:
    Any idea as to what might be causing this, as it has become more pronounced over time? I did clean out the fan recently.
    (Mind you, I'm not based in the US, and this car is an import so I can't take it to Toyota)
  2. PriusCamper
    PriusCamper Senior Member
    13,345
    5,395
    Pacific Northwest, USA
    Did you open it up and look inside? Their could be something really cool in their that'd make this post way more interesting. :) One time I had a giant moth fly into my cooling fan... Was such an amazing thunk every time it bounced around... OR then there was this one guy on here with a rodent issue... As in let's see what's in there / time to unwrap the present....
    Raytheeagle and dig4dirt like this.
  3. bobisshortforbobert
    Pakistan
    2014 Aqua
    I did open up the assembly to the point where I unbolted it from the base and removed the grille. I cleaned the fan's blades because they were very dusty. However, I did not completely dissemble the fan (it has these three very tough screws on the back).
    Could this be a mechanical issue? It appears to be caused by the fan itself moving back and forth in its assembly possibly.
  4. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Personally I wouldn't worry about it as long as it's functioning. It's just barely tapping the inside of it's cover and it's not hitting on a fan blade because the outer "rim" is what's going to hit first.
    If you no longer hear the ping - then buy a new fan.
