Noise in prius engine
Discussion in 'Gen 3 Prius Technical Discussion' started by Wahid D, Nov 15, 2017.
  1. Wahid D
    Wahid D Junior Member
    Lahore
    My prius making noise in engine
    please help me to fix it out and let me know why prius making this kind of noise
  2. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    Whereabouts on the engine are you talking about?
    What kind of noise are you referring to?
    What sort of mileage does the engine have?
    I can hear a tapping noise but I’m not sure if that’s what you are referring to.
    2010 Gen 3
  3. Wahid D
    Lahore
    Sir watch this video again please, the noise is coming from engine's down side and its not tapping noise, noise is like something cracking, engine's total mileage is about 79 thousand and engine performance is good but this noise is really scary :(
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Camera is panning too much to know where and what sound your talking about
  5. Mendel Leisk
    42,310
    I think the noise that's bugging him, is this kinda rapid drumming/knocking, intermittent sound, over top of the regular engine sound.
  6. Jayw13702
    142
    170
    Plymouth UK
    Now you have pointed that out I can hear it.
    It sounds like something is loose and banging/rattling about, but what I cannot tell
    2010 Gen 3
  7. bisco
    52,812
    is this in the warm up cycle? can you give us more details?
  8. Wahid D
    Lahore
    exactly now you are on point (y) We have checked gear oil, silencer clips all engine shields but all are ok, this noise is in engine, when i start my prius in morning when engine is cold this noise is more than engine voice, but after few minutes its reduce
  9. Wahid D
    Lahore
  10. Mendel Leisk
    42,310
    Timing chain? Or one of the coolant pumps? Are there two of those?
  11. Jayw13702
    142
    170
    Plymouth UK
    When was the transmission oil changed?
    2010 Gen 3
  12. Wahid D
    Lahore
    may be or may not be, but my mechanic said one of engine connector rad is damage? is it possible?
  13. Wahid D
    Lahore
    few days ago before 79 thousand miles, transmission oil was less than 4 liter, 1 liter was less
  14. Mendel Leisk
    42,310
    Piston connecting rod? Yeah, no clue, need more educated ears.
  15. Wahid D
    Lahore
    yes, you are right
  16. Jayw13702
    142
    170
    Plymouth UK
    I have a very similar noise in my 2010, it’s now done 141,000 and never had a transmission oil change.
    When I’ve had a listen around for it I would have said it comes from transmission and not engine.
    I have a very limited knowledge of cvt transmission but my first thought was the drive belt making that noise, as it gets warmer the noise stops because whatever it’s running against expands and so reduces the “slack”
    I don’t think that’s a connecting rod, but the only way to check that would be to take the head off and measure the piston against the deck height
    2010 Gen 3
    Wahid D likes this.
  17. Mendel Leisk
    42,310
    This was determined by drained amount, during a replacement?
    The spec'd. amount at replacement is 3.3 liters, so if 3.0 liters drained, that is not far off. Proper level is most simply achieved by filling with the car level, till it's starts coming back out of the fill hole, wait till the overflow subsides, then install fill bolt. Doing this, it takes me a bit over 3.5 lliters, maybe a bit more. There's a small amount of spill involved.
    So, while I don't know enough to comment on it being the transaxle, at least the level doesn't seem overly low. How did that drained fluid look. If it's first drain I'd expect it to be quite dark.
    Wahid D and Jayw13702 like this.
  18. bisco
    52,812
    what engine oil are you running?
  19. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I thinkbyou need to post more details on the noise from that car. You've got different noises just coming out from the engine
    Dxta
    Grit likes this.
  20. Joele3
    Joele3 Active Member
    137
    205
    Bay Area
    This sounds exactly like the knocking from a blown head gasket. Misfire at start up or condensation inside the intake manifold.
    Tbkilb01, amos and bisco like this.
