noise in reverse
Discussion in 'Gen 4 Prius Main Forum' started by Dennis Palmer, Jul 9, 2022.
  1. Dennis Palmer
    Dennis Palmer Junior Member
    Bradenton FL
    2020 Prius
    My 2020 Prius make a grinding sound when backing up. Can only hear it out side the vehicle. At first thought it was brake pads making noise. thought it would go away but 10000 miles later it is still there. Asked at the dealer and they said it was designed this was so that people knew the car was moving. Is this BullS**t on normal.
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Your dealer is talking about the "spaceship" noise that is generated at low speeds in either direction. Does the "grinding noise" only occur when you engage the brakes? If so it is rust on the rotors and you can clean them by getting up to 25-30 MPH, putting your Prius in neutral (to shut off regenerative braking), and applying the brakes lightly. Repeat as required to eliminate the noise/rust.
    JeffD
  3. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    I'm pretty sure it's normal. Mine only happens in reverse, and it's not a grinding. It's more like a wet finger on crystal drone or a bad wheel bearing sound (if you've ever experienced that). You probably only noticed this, once you've turned-off that incessant reverse beeper and you have your windows rolled down.
    If you had a real problem, the grinding sound would persist - moving forward or back. Since your issue is isolated to reverse, I doubt you have a problem. If you think I'm full of BS - Find someone else with a Prius and have them throw it in reverse. Unless they modified or clipped that external buzzer; It should sound similar.
    Good Luck......
    PS. It needs to be a 2017 or newer Prius. The older ones had something similar, but they sounded way different.
  4. Jburner
    Jburner Member
    68
    44
    Wisconsin
    It's actually a speaker in the front. They had to add the speaker to make a noise when the car was moving for safety reasons.
  5. bisco
    52,878
    ifit were the VPNS, it would make the same same forward or backward up to 15mph or so.
    open the drivers window and listen in both directions with the engine off.
    Electric_vehicle_warning_sounds
  6. Dennis Palmer
    Bradenton FL
    2020 Prius
    Do you know where the speaker is located? Or at least close to where it is located
  7. bisco
    52,878
    somewhere in the engine bay, there's at least one thread here somewhere
  8. bisco
    52,878
  9. A strolling player
    A strolling player Junior Member
    33
    New Orleans, Louisiana
    2022 Prius
    It’s not only on in reverse, it also sounds in drive when the gas engine is off up to 22 mph. It’s much louder in reverse so people behind the car can hear the sound, because the speaker is up front.
    Reypac24, bisco and Doug McC like this.
  10. bisco
    52,878
    that's interesting, i had not read that before. makes sense though
  11. BiomedO1
    4,635
    2,433
    Left Coast
    LoL; I'm getting old and my hearing is going anyways. I had a service call today about an incessant hum - I couldn't hear it. So I unplugged the monitor, and she said it was still there. I unplugged the UPS, and she goes - it's gone, but can you do something about the alarm?:p:D:cool:
    So I asked her, which is more annoying - the alarm or the hum. She says, well the alarm. Great!!! another satisfied customer!!!!:D
    Actually, I told her it'll take me about a week to get you a new UPS.:whistle::ROFLMAO::LOL::cool:
    #11 BiomedO1, Jul 12, 2022
    Mambo Dave likes this.
  12. Media_Tech
    Media_Tech Junior Member
    inside the Beltway
    Maybe the clutch? IIRC it need to disengage the drive train from the ICE for the car to be able to go backwards.
  13. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is no clutch in a Prius (other than a "torque limiter")
    JeffD
  14. Media_Tech
    inside the Beltway
    John Kelly, WeberAuto:
    2016 - 2022 Prius, Prius Prime Transaxle - P610 Deep Dive (P710, P810 Similar)
    Toyota - YouTube
    starting at about 9 minutes into video.
  15. bisco
    52,878
  16. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    whoah.
    I must have skipped over that part back when I watched the video. I'm still impressed that two rotors are turning up to 17,000 RPM in there.
    #16 Mambo Dave, Jul 15, 2022
  17. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Yes, new models are MUCH louder in reverse. Different sound, but nearly the same volume as an idling diesel truck. Seriously annoyingly loud.
    As for Professor Kelly, his Prius videos should be required viewing for Prius owners.
  18. ChapmanF
    19,041
    A direct link to that P610 deep dive video makes it easier to see what part you're referring to.
    At around 9 minutes, Prof. Kelly starts talking about what he calls the "clutch" damper, as you can see here. JeffD knows about that; it's what JeffD called the "torque limiter". Toyota's parts catalog calls it the transmission input damper assembly.
    If you've looked at clutches before, you can see this looks a lot like a clutch pressure plate and clutch disc permanently assembled together, but with no means of releasing, ever. It has the coil springs that take up brief pulses in shaft torque, and it is able to slip slightly whenever there is torque that would exceed the mechanical limits, but that's all it does. All the rest of the time, it just rotates as one assembly; it does not act in any way as a clutch that can release. Every Prius has one of these.
    A minute or so further into the video, Prof. Kelly discusses (but does not show) an additional "clutch" that only exists in the Prius Prime. The sprag clutch lives between the engine block and flywheel, and is simply a fixed type of one-way clutch that won't let the engine spin backward. It is needed in the Prime because the electric motors can drive the car forward at higher speeds, by pushing off against the engine crankshaft, which therefore has to be held against turning backward.
    So in a Prius Prime, there are two kinds of clutch-like thing, but still nothing that ever disengages the engine from the drivetrain.
    #18 ChapmanF, Jul 15, 2022
    jerrymildred likes this.
