Noise under engine after power down
Discussion in 'Gen 3 Prius Main Forum' started by solrunner, Jul 7, 2022.
  1. solrunner
    solrunner Member
    114
    37
    Reston, VA
    Anyone want to guess what this sound could be? It occurs after driving, parking, and turning off the car. It sounds like it's coming from under the engine. It lasts about 5-10 minutes then fades. I started noticing it a few weeks ago. No other issues with car. The car has 75,000mi. 2013.
    Any thoughts appreciated! Thanks.
    #1 solrunner, Jul 7, 2022
  2. nicoj36
    nicoj36 Active Member
    518
    162
    It might be your catalytic converter. You should jack up the car and get under, remove under covers so you can get a better look and find out exactly where it's coming from.
  3. Classic Car Guy
    Classic Car Guy Active Member
    502
    135
    Northwest, USA
    "turn up your radio...!":eek:
    Hard to tell from here. it sounds like a shield rubbing, or a waterpump, idler bearing. Or check the belts if loose or needs replacement or belt dressing. check your catalytic or manifold shield. check you exhaust flange. I couldn't make it up in your video. Not loud enough or atlease rev it when your running your video so you can see the action of the engine of its moving or tilting while reving. A busted mount will actually contribute to that sound if the motor is not sitting properly...
  4. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    No belts on a gen 3 prius
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,349
    979
    Monument, Colorado USA
    So it only does it when the car has bee running and hot, right? I'm suspecting catalytic converter and/or some heat shields just cooling down and wouldn't worry about it.
    I've gone out into my garage and heard noises coming from the Prius that hadn't even been ran that day and discovered the evap system sometimes does air cycling even when the car isn't being used.
  6. Lares_Mat
    Lares_Mat Member
    199
    59
    Solrunner wrote:
    "It occurs after driving, parking, and turning off the car."
    Doesn't he?
    Mat
  7. Mendel Leisk
    42,345
    Does the sound start immediately after shut down, or there’s some delay?
    just grasping at straws.
  8. Lares_Mat
    Lares_Mat Member
    199
    59
    I heard in once again and have a feeling, sort of "I heard it already!".
    No idea when and where and what was it - sorry...
    The sound is to "dynamic" for me to be some part contracting on cooling making it.
    I suspect some pressurized gas decompressing - evaporating system, cooling system, braking system (what I can think of).
    Non of the above is actually good leaking pressure ;)
    Interesting is, it can be heard actually all over the motor compartment...
    And - are you sure, the sound comes up only if the engine is off, or if it is running too, but is not loud enough to be heard?
    Could it be one of the pistons? If it has stopped short from being ignited? Is it technically possible?
    Mat
  9. ChapmanF
    19,020
    I'm gonna go with A/C. If you have driven, parked, and turned off the car while the A/C was running, then right when you turn it off, the refrigerant is mostly stuck on one side of the system as liquid at around 220 psi, while on the other side it is vapor at around 30 psi. The liquid on the high side will be squirting through the TXV for a while and boiling off into vapor on the low side, until eventually both sides are matching at around 90ish psi (more specifically, both sides will end up at the "saturation pressure" for R-134a at whatever the surrounding temperature is).
    That is one kind of "leaking pressure" that isn't any kind of problem at all. :)
    Edit: an easy way to check if I'm right would be to go make a similar drive but without using the A/C at all.
    #9 ChapmanF, Jul 8, 2022
  10. solrunner
    solrunner Member
    114
    37
    Reston, VA
    Thanks for all the replies. I will review carefully later and try some more things this weekend.
    Not sure if this is a coincidence, but I first noticed it after spraying AC deodorant/disinfectant into the vent under the windshield, while on full blast, according to the instructions on the can and from watching videos online. Seemed quite safe from my research.
    I may have already tried a trip without AC but will try again and listen carefully this weekend.
    It sounds to me like some liquid or gas depressurizing or something. No leak under the car besides normal AC condensate.
    Does anything in the engine bay normally run or pump fluid after turning off the car completely?
    Thanks for the replies helping me track down this sound!
    #10 solrunner, Jul 8, 2022
  11. solrunner
    solrunner Member
    114
    37
    Reston, VA
    Yes, only after hot and having been run.
    How did you discover that on your car? The noise you just recognized from previous experience on other cars or something? Thanks.
  12. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Just heard identical sounds today on our 2011 Prius after running the car for only a few minutes with the AC on to check all the signal lights and exterior lights prior to getting an annual safety check.
    It's the AC lines or compressor, it's normal, I wouldn't worry about it.
  13. ChapmanF
    19,020
    Precisely. It's liquid R-134a squirting through a tiny expansion valve and boiling off into R-134a vapor. Once you turn the car off and the compressor stops, it'll just do that, until it reaches the same pressure on both sides.
  14. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    Refrigerators do that too, for the same reason.
  15. solrunner
    solrunner Member
    114
    37
    Reston, VA
    Well that's good to hear, hopefully it is just normal AC operation. Seems odd that I never noticed it before, having bought the car new 8 years ago. Thanks.
  16. ColoradoBoo
    1,349
    979
    Only by accident! There's a Master Toyota Technician on YouTube, Ahmed ("The Car Care Nut") who said he's lost count of new hybrid owners who return to the dealership complaining their hybrid is broken, makes all kind of weird noises from the "UFO" speaker when you drive slow or backup, to the regenerative brakes charging the brake fluid when you open the door to the evap system.
    He, also, warns folks over and over to NEVER top off their gas tanks when filling up because he's seen folks who do this getting gas in their evap cannister and it has to be replaced.
    nicoj36 likes this.
