Noise when in complete stop and brake pedal is depressed
Discussion in 'Gen 2 Prius Technical Discussion' started by MJ50, Jan 9, 2019.
  1. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    brake actuator assembly was replaced under warranty.
    this noise started sometime after.
    flushed brake fluid. no help.
    if i release the brake pedal just enough where car won't roll, the noise goes away temporarily.
    any idea what's wrong?
    51,155
    is the engine running?
  3. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    yes
  4. padroo
    padroo Senior Member
    2,763
    2,251
    Is it coming from one side or both, front or back?
    If it is only coming from one wheel I would pull a wheel and take a look at it.
  5. bisco
    51,155
    i can't really hear it over the engine, can you record without the engine on?
  6. padroo
    2,763
    2,251
    The engine was running?
  7. bisco
    51,155
    see post #3
  8. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    it's coming from the front, definitely not from the back.
  9. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    i'll try to get a better clip next time
  10. bobodaclown
    bobodaclown Member
    216
    72
    Hello, just had a similar experience. The repair shop was going to rebleed the brakes, when I brought the car in. I did several aggressive brake stops, up to 40 then full stops, enough to feel the antilock kicking in. It worked. Noise went away. I realize that's not an approved fix, but it worked in my situation. Your results may vary. ;)
  11. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    here's another video with ignition on
  12. bisco
    51,155
    that's without the engine running?:eek:
  13. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    correct. everything runs fine, but just a noise...
  14. bisco
    51,155
    maybe the brake actuator, hard to tell. definitely sounds like a pump or motor.
    are there any trouble codes?
  15. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    brake actuator was replaced under warranty and it was a different noise...
    no codes...
  16. bisco
    51,155
    is it possible they bungled the job?
  17. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    not sure... that's y i flushed brake fluid just in case...
  18. JC91006
    16,674
    8,519
    Check for that noise outside of the car, with the hood raised. If it's the actuator/accumulator you'll hear it.
  19. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    i'll need extra feet but will make video from the engine bay next time...
  20. Sharnold
    Sharnold Active Member
    394
    123
    Alabama
    It sounds like the brake actuator as mentioned above one sure fire way to know is with the car not running but in ready mode press the pedal till you hear it let off quickly then press harder if the noise gets louder than before more than likely you have air in the system
