noisy a/c compressor?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bucky35, May 21, 2014.
  1. Bucky35
    Bucky35 Junior Member
    37
    NorCal
    What is everyone's experience with the plugins a/c compressor? Seems awfully noisy to me, this is from inside and outside the car.
    Much noisier than the mandated noise maker.
  2. JC91006
    16,923
    8,634
    what year are we talking about?
  3. markabele
    5,084
    1,782
    Nebraska
    I assume he has a new-ish PiP if he is posting on here.
    Yes, it does make some noise. While I necessarily wouldn't call it noisy...I can only hear mine if I'm stopped and it is pretty quiet around me.
  4. JC91006
    16,923
    8,634
    I was thinking it was a newer one, however his avatar and "your vehicle" is a GenII
  5. Bucky35
    37
    NorCal
    2014 PiP, reason I ask is my Gen II a/c compressor is pretty quiet. The 2014 PiP a/c sounds like a soft version of a bicycle with a card in the spokes.
  6. Cave Arnold
    Cave Arnold Member
    64
    60
    Lehigh Valley, PA
    I have a new 2014 PiP only a month old now. I never noticed the a/c compressor even when I took short all ev trips. I normally have the radio on, but today turned it off and made sure the a/c was on then listened. Inside I heard a quiet fluttering sound, outside I heard less. Initially the fan went to high and that noise covered the a/c noise on the inside. I drove about 10 miles all ev with the radio off and did not really notice the compressor sound over the road noise. I normally listen to the radio all the time, but with the radio off today the a/c compressor did not sound abnormally loud to me.
  7. bisco
    52,680
    mine has a slight buzz to it, no biggie. maybe it's more efficient? hardly seems to use any battery.
  8. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I noticed this for the first time recently as well. From outside the car, it sounded exactly as described above - like a bicycle with a card in the spokes. Anyone else noticing this?
    The Tesla forums have complaints about the same issue, so I wonder how much of this is just the fact that nobody has really worried about a/c compressor noise when packaged next to an ICE and it's just more obvious in an EV?
    markabele likes this.
  9. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I just noticed today, after 46k on my 2012, that the loud hum from the AC compressor has turned into slight gurgling while humming. It's always been the same loudness but the sound changed...I wonder what is wrong.
  10. bisco
    52,680
    hopefully nothing. but you may want to listen to it at the dealer and compare the sound to a new one.
  11. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I want to take it in, but don't want to waste my time for them to tell me it's nothing. It's out of warranty anyway, and it still works the same as it did before. But the noise has definitely changed from...earlier in the week I guess. I was using remote AC a lot today so I was outside the car to hear the noise. It was parked and plugged in.
  12. bisco
    52,680
    it definitely sounds different outside the car than in.
  13. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Yes it does. It's muffled and quieter inside. Half the time I have to stop and go back in the house for something I forgot. I leave the car on. So I think I'm familiar with both. It's like the AC is gargling while humming instead of just humming.
  14. bisco
    52,680
    not the inverter pump or something?
  15. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Nope, it shuts off when you hit the AC button to turn the AC off. Also, it keeps going with the AC on when the radiator fans shut off. It's coming from the passenger side of the engine, front, bottom.
  16. trentofdestiny
    1,104
    227
    Harrisburg, PA
    If I may... here are some videos I took, of MY noise. Hopefully someone has had something similar. I will also check with the dealer tomorrow.
  17. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    The A/C system might have some air in it!!:eek:
    Take your new 2014 Prius back to the dealer, and have tech hear it.
    Somebody might not have pulled a vacuum on it, before they charged it up with freon gas.
    Air in the A/C system can be very LOUD!!:(
  18. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Idk about the OP but mine hasn't been recovered and recharged ever.
  19. GregP507
    GregP507 Senior Member
    3,002
    481
    Mine is almost silent, but I have observed that compressors sometimes get much noisier as they begin to wear out.
  20. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I went to the dealer and 10' away the tech said yup, your compressor is going bad :( getting an estimate tomorrow.
