noisy a/c compressor?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bucky35, May 21, 2014.
  1. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    Mine sounds like that. ('14, 6500 miles).
  2. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Yikes, dude. Get it fixed before it implodes and puts metal through the system. It's a no brainer for you since you're still under warranty. Lucky lol
    52,849
    why replace it if it's working? might last 5 more years.
    markabele likes this.
  4. trentofdestiny
    1,104
    227
    Harrisburg, PA
    The actual tech at the dealer (not just any service person) said it was going bad. I assume they have seen this before, although maybe not this new.
  5. GregP507
    GregP507 Senior Member
    3,002
    481
    There's a point to be made either way. Catastrophic failure is very destructive, but simple slop in the compressor can persist for a long time before failure. I'd say if it seems to be getting noticeably worse over a short period of time, better get it fixed.
  6. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I agree. I didn't hear mine develop the noise from one day to the next, but it was definitely normal in the past week
  7. bisco
    52,849
    don't forget, the tech is not independent of house money.:cool:
  8. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I know. I will probably end up having them install a used unit. I'd do it myself but I don't have separate equipment to avoid contamination and to measure that small of a charge.
  9. GregP507
    3,002
    481
    I'd hesitate to let the dealer do any major overhaul for something which isn't covered by warranty. At least, not before I checked around to see what other options were available.
  10. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Yeah that's why I thought of using a used part and not letting them make money on a new one. But it's still x hours of labor no matter where you go, on recover and recharge AC
  11. markabele
    5,084
    1,782
    Nebraska
    Trent,
    Curious to hear about your AC usage that may or may not have impacted this premature wear. What do you usually set your AC at? Do you use it much when the car is not in motion? How many total miles do you have?
  12. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I normally have it set all the way down at LO and air on vent or vent&floor. I do use remote AC once in a while with the car plugged in. I pretty much live on AC in the summer. I have 46k miles.
  13. GregP507
    3,002
    481
    Could be low on fluid. Power-steering pumps sound similar when they're low on oil.
    Or perhaps over-filled.
  14. markabele
    5,084
    1,782
    Nebraska
    Holy crap you like it cold, haha!
    Even with this sort of heavy usage you would expect it to last longer than this though.
    trentofdestiny likes this.
  15. GregP507
    3,002
    481
    Another possibility is "floodback." Too much refrigerant leaking through the pump and into the crankcase.
  16. bisco
    52,849
    why is it attached to the crankcase?
    rxlawdude likes this.
  17. trentofdestiny
    1,104
    227
    Harrisburg, PA
    He means the crankcase of the AC pump, which a somewhat of a misnomer, because it doesn't use a crankshaft with connecting rods and pistons, but it's the housing around the scroll.
  18. mr_yellow
    mr_yellow Junior Member
    66
    Technology
    Can anyone confirm what the root cause of the noise is? I have a 2010 Gen 3 with <60k km that I bought used and it's making this noise now! My dealership says they won't inspect since it's not covered under warranty anymore... Is it a simple fix or does the compressor need to be replaced?
  19. bisco
    52,849
    no, but i wouldn't worry about it as long as it's working.
  20. trentofdestiny
    1,104
    227
    Harrisburg, PA
    The compressor needs to be replaced. A little research on home HVAC with scroll-type compressors shows that ANY noise is MOST OFTEN really bad, except for the normal electric motor hum.
    If the compressor dies then it will most likely send metal into the condenser and perhaps other parts of the system. The condenser is a parallel flow type which can't be flushed out, so it will need to be replaced as well.
