Noisy startup? (55k miles) 2018 prime
Discussion in 'Prime Main Forum (2017-2022)' started by Sunde, Dec 29, 2023.
  1. Sunde
    Sunde New Member
    Denmark
    2018 Prius Prime
    Hello gents, this is my first (of probably a few) posts on the forum, happy to be here. :)
    Im the lucky owner of a 2018 Prius Prime with 55k miles on it currently.
    I'v noticed on startup (its cold here in Denmark) the engine is somewhat noisy, and is also a bit "ticky" when it idles, at least more than i'd usually like. Oil is pretty fresh and is topped off to spec, same with coolant.
    At first i thought it was maybe a timing chain issue, or maybe valves i was hearing, but im not sure anymore... Reading about this engine (im only used to motorbikes this is my first car in fact!) i can see that it has multi port injection, could it be that im hearing the different injectors cycling during startup?
    The above sums up my question to you guys.
    When i switch the car from EV to Hybrid mode (when stationary and cold) and the engine fires up, i hear the noise ever so slightly even when inside the cabin, followed by a very gentle vibration/jerk in the car that i assume comes from the whatever generator trickery this car uses to spin up the engine (it does not have a traditional starter as far as i know?)
    Feel free to edcuate me if this is total nonsense, i find the design of the engine/hybrid system very cool!
    Thank you so much for any input!
    Obligatory pic of the car :D
    TGrracie and bisco like this.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You're overanalyzing it. The ICE makes a lot of racket when cold and when working hard. It also jerks the car if it starts when you are stationary. I imagine it's especially noticeable in the Prime where you spend a lot of time in smooth and silent EV mode.
    Sunde likes this.
  3. Mendel Leisk
    42,347
    some the earlier years of Gen 4’s (2016-2022) have had coolant leaks in the exhaust heat recovery system. May or may not be a factor, but worth checking. Engine coolant level in reservoir is stable? Just note where it is, cold, then check again, say in a month.
    Sunde and bisco like this.
    52,855
    congrats and welcome! all the best
    Sunde likes this.
  5. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Exh cam phaser set to send flames to b1s1 air:fuel ratio sensor triggering closed loop sooner. Normal operation. You're listening to raw flames shoot out the exh valves. Camry and rav4 do it too
    #5 douglasjre, Dec 31, 2023
    Sunde likes this.
  6. Sunde
    Sunde New Member
    Denmark
    2018 Prius Prime
    Yeah you guys are right, it seems inconsistent (as to when i hear the noise) unsure if thats just because i cant always pick it up, or if its a just a noise it "sometimes makes" but regardlessly my experience is that a mechanical noise that is only periodical usually means that either its "just me" being hysterical, and not the vehicle having an actual issue, or at least its not something serious.
    That and the fact that this thing runs on SUPER thin oil likely just means i have to get used to an engine with a different kind of noise compared to my motorcycle. :) Thanks y'all!
  7. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    If the engine has been off for a long time there may be a second or two of dry start as the oil fills the galleries to the moving parts. If yours has the cartridge oil filter, from my short experiences, some aftermarket oil filters do not align correctly on the center tube. I would stick with a Toyota filter carefully installed. My Prime is very quiet as the engine starts and stops, no vibration, no big engine noises. I find it to be a pretty quiet engine. On the highway, cruising, the engine is going on and off frequently and imperceptibly. I wouldn’t notice except for the screen icons showing the engine going on and off. I don’t put any sound on when driving.
    Sunde likes this.
  8. Sunde
    Sunde New Member
    Denmark
    2018 Prius Prime
    I plan to do an oil change when the weather warms up, i'v got the oil and OEM filter ready and waiting :)
    I hope to find an original toyota filter on it when i do get to it, as far as i know its only ever been serviced at a dealer.
  9. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    The 2018s use a "normal" non-cartridge oil filter.
    The engine on my 2018 definitely rattles a bit on startup, but after warmup its reasonably quiet. Definitely no ticking noises - if this is happening while the car is moving, its possible the brakes may be dragging a little. Just apply them a few times and it should go away.
    If you hear ticking noises while the vehicle is stationary and the engine is running that is another story.
  10. Trollbait
    12,829
    Cars are under stricter emission regulations than motorbikes. Most(all?) cars run the engine at a higher idle on start up to warm itself, and the catalytic converter, up to reduce the start up spike in emissions from a cold start up as soon as possible. That will make usual engine noises more pronounced even without considering noises that are start up only
    :D 0w16 viscosity is actually really close to 0w20 that most other cars use. Maybe motorbike oil is thicker, but the numbers on the label are specification numbers. Beyond higher being thicker, they aren't reflective of actual viscosity measurements. A 75w90 gear oil can have the same viscosity as a 10w40 motor oil. The different operating environments require different properties elsewhere. Since adding gear oil to an engine can be very bad, the SAE went with label numbers far apart to reduce such errors.
    #10 Trollbait, Jan 4, 2024
    Sunde likes this.
  11. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    Have you tried different oil filters? I don’t seem to hear any startup rattle on the one I have now, except when the engine wasn’t used for about two months. The first Prime I had seemed more prone to it, and I “feel” it was worse after the N1 was installed.
    Looking at the oil filter adapter there is an in and out port that goes to the oil filter. When the engine is turned off all the oil galleries are full. If there is any leakage at the filter anti drain valve the galleries will empty. But it seems when the emptying reaches the levels of the adapter in out holes the oil would stop draining. Maybe the chain tensioner drains and there is noise until it is pressurized again. That wouldn’t be so harmful like the engine bearings. I don’t know if siphoning could occur through the oil pump to oil filter. It’s pretty complicated.
    I’m defining start up rattle as like one second.
    Using Wendells excellent links references in his posts, he shows pictures of the oil filter adapter mounted. The lower pipe would be the inlet to the filter. The higher pipe is from the filter center tube up into the engine. So if the oil does drain to the lower pipe seeking a common level, it looks like the main bearings would drain. But it would have to drain down through the oil pump. Toyota filters seem to have excellent anti drain valves, but that’s by looking at them.
    The oil filter adapter is much better than on my 96 where a single oring inside the adapter separates the in from the out sides. There is virtually no way for this to happen with the two separate orings on the Prius filter adapter. But it could leak out of the adapter which us easy to see.
    Whew, my goal in this is to not have any start up rattle in the Prime as it does go periods of no engine use. I would say the anti drain valve in the filter is key.
    #11 Mr.Vanvandenburg, Jan 4, 2024
    Sunde likes this.
  12. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    @Mr.Vanvandenburg - I would be cautious about introducing any types of adapters where the engine oil is concerned. One leak and it could be a very expensive repair. The last quote I received for engine replacement on my 2017 after the oil pan was punctured was north of $20k.
  13. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    The oil filter adapter I’m talking about is what comes on the car from the factory. The anti drainback valve in the oil filter stops the oil from draining down. If oil drains down there can be start up rattle until the oil gets back up in the engine.
    See the posts on oil filter conversion for pictures of the adapter.
    #13 Mr.Vanvandenburg, Jan 6, 2024
  14. Trollbait
    12,829
    It took it more as a warning about doing after the car was made. Factory parts can still be installed wrong with leaks.
  15. ChapmanF
    19,025
    Does the Prime have variable exhaust cam timing? My Gen 3 can only vary the intake.
    But I think it does use late ignition timing during early warmup for a similar effect.
  16. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Depending how your Prime was driven the last 4 winters, it's possible that the EV to HV switch over never settled down. Other owners, including me, have noticed that the engine switch on from EV mode can be rough, especially if the engine is under load during the switch over. Without the full history of the Prime, it's not going to be easy to pin down exactly what you are noticing and if it's related to how the car was driven the last 4 winters, but yes engine shake in the EV to HV switch over is real. It most noticeable when there is no EV range left and the engine has to do all the work of moving the car while it's in the warm up cycle.
    Sunde likes this.
  17. douglasjre
    2,250
    751
    Null, NL
