Nokian Tires issue
Discussion in 'Gen 2 Prius Main Forum' started by Freedom, Jan 8, 2026.
  1. Freedom
    Freedom Active Member
    553
    73
    Northeastern MA
    Carmine has a mix of Nokian tires: WRG 4 and WRG 5, because the "4" is discontinued. Four season tires, no need to change tires winter and summer.
    Got a flat, need a new tire. Shop put on a Hakkapelitta, which is a winter tire. Manager says it is basically the same, has a bit more rubber, no need to change it for summer. The WRG 5 no longer comes in my size of 185, only comes in a 195 which is a larger tire. He says if I want something else, he will swap it for me.
    Now Carmine has one WRG4, two WRG 5, and one Hakkapelitta. These are all LRR - low rolling resistance.
    Northeastern MA.
    Thoughts?
    #1 Freedom, Jan 8, 2026
    52,695
    if you're not having any problems, i wouldn't worry about it
  3. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    You have 3 185 working with no lights with one 195 on car? Interesting .
  4. Freedom
    553
    73
    Northeastern MA
    Ahahaa, no no no. I do not have ANY 195 tires. It is because the WRG 5 is now only available in the 195 size that he switched to the Hakkapelitta. All 4 tires are 185 size.
  5. Freedom
    553
    73
    Northeastern MA
    I have been in contact with Nokian customer service, received this info:
    We do not recommend leaving a winter tire on year-round as warmer temperatures above 45 degrees Fahrenheit or above 7 degrees Celsius can compromise the compound of the Hakkapeliitta tires, which could leave to compromising your safety.
    They are now working to locate a tire for me.
    Thought you would like to know, @bisco.
  6. bisco
    52,695
    thank you freedom!
    Freedom likes this.
  7. Tombukt2
    13,765
    2,491
    Durham NC
    By the time I get in touch with the tire manufacturer and they get back with me and they spout all the tech . I've already worn the tires out so it's all moot here .
  8. Freedom
    553
    73
    Northeastern MA
    Ahahaaa. So far, I've exchanged 7 emails with the Customer Rep at Nokian. He is now searching for a tire for me. The tire shop I went to can only access the distributor they contract with. Nokian can check with all the distribution warehouses. If he can't find one, he said I may need to buy 4 new tires; but he said not to worry about that yet as he has all my records, knows I've been a long term customer, and he can work something out if it comes to that. Very responsive!
    Tombukt2 and bisco like this.
  9. Freedom
    553
    73
    Northeastern MA
    Sorry I did not post sooner. Issue resolved.
    Nokian Customer Support sent me this info:
    "We do not recommend leaving a winter tire on year-round as warmer temperatures above 45 degrees Fahrenheit or above 7 degrees Celsius can compromise the compound of the Hakkapeliitta tires, which could leave to compromising your safety. "
    When I shared this with the tire store manager, he paused and then said, "I would agree with that." Grrr
    I now have a Nokian One tire on. Replacement of the Hakkapelitta was done free of charge and, since the Nokian One costs less, I also received a partial refund. All completed on Friday Jan 16th. It was a frustrating 19 days. Very time consuming. And should NEVER have happened.
    So that's TWO tires stores I won't use again. (The other one was due to an issue 3 years ago.)
  10. rjparker
    rjparker Tu Humilde Sirviente
    10,887
    6,833
    Texas Hill Country
    I run Michelin Cross Climate 2s year round since South Texas now gets ice storms every year since 2021. Before 2021 it was one per decade, maybe.
    Freedom likes this.
