nominal voltage very high in a module
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Juan Arana, Jun 4, 2023.
  1. Juan Arana
    Juan Arana New Member
    Hello there, I’m new here. I have a Toyota Prius 2014 with 134K miles. The other day I got the message on the dash ‘CHECK HYBRID SYSTEM. STOP THE VEHICLE IN A SAFE PLACE’ then I got the code PA080 with Dr. Prius and tech stream. I read some posts to do something before thinking to change the whole battery. Clean the fan, the filter. The bus bar. I did all those things and I measure every single module above than 8V… 8.22V, 8.10V, 8.24V, etc.
    If the nominal voltage is 7.89V. Why do I have more than 8V??? All my modules are bad???any idea or suggest what to do? Thanks in advance.
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Depending on your state, Your car migh still be in the warranty window, don’t wipe the code and take the car to a Toyota dealership and get a free replacement.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    When the p0A80 is triggered, it's normally due to one or two modules failing low. It kind of fools the car into thinking the overall SOC is low and the battery is typically placed into a charge condition, which will result in a "real" high level of "state of charge" on the good modules. The modules will typically be over 8v, as they are typically above the normal 40-60ish% range maintained by the car. A bad module will often drop in voltage relatively quickly of you allow it to sit idle. Often, but not always.
    Juan Arana likes this.
  4. CatNinja
    CatNinja Member
    71
    48
    Hawaii
    2023 Prius Prime
    XSE Premium
    Voltage for a NiMH battery is 1.2 - 1.3v for about 20 - 80% charge (or 7.2 - 7.8v), but could get to 1.4v (8.4v) when fully charged, so over 8v is normal. As TMR-JWAP says, the car tries to keep the battery at 40-60%, so it normally stays at about 8v, but can go much higher, for example, at the bottom of a hill.
    Just let them sit for a couple of days, and the failing modules should be pretty easy to find as they would self discharge to a much lower voltage than the other modules. You can also test them with an RC hobby charger/discharges to get a more exact capacity value. A new module is 6.5Ah.
  5. ChapmanF
    18,969
    I'm not sure where you got that figure ... nominal voltage for a six-cell NiMH module is lower than that, 7.2 volts specifically. But also, nominal voltage is just that—a number that is named for talking about things—and as CatNinja explained, it's not weird at all for the actual voltage in a charged battery to be above that.
  6. Juan Arana
    I'm in Florida, warranty for 2014 is 8y/100K.
