non-ethanol fuel
Discussion in 'Gen 3 Prius Main Forum' started by thetourman, May 17, 2021.
Tags:
  1. thetourman
    thetourman Junior Member
    Alabama
    I just want to verify something I believe I can do.
    The generator I just purchased for power outages after hurricanes uses non ethanol fuel.
    Can any unused non ethanol fuel be used in our 2010 Prius and 2017 Prius V?
    Thanks
    rampante550 likes this.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    Yes. Its is better than ethanol fuel. But too expensive to use routinely.
    rampante550 and thetourman like this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It probably specifys that because E0 fuel stores better/longer than the ethanol blends.
    But it really is not good to store a generator with fuel IN IT regardless.
    So yes, you can have a couple of cans with E0 in it for gen use and "rotate" them through your car every 6 months or so.
    The best emergency generators use natural gas or propane for fuel so you don't have to worry about stale fuel.
    thetourman likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    In Washington State we have a handful of gas stations that sell non-ethanol fuel at the pump and surprisingly it doesn't costs much more, less than a dollar a gallon than regular unleaded. It has 2% more BTU than 10% ethanol gas and doesn't absorb water or create laminates inside the engine like the corn lobby's garbage ethanol fuel does. As for how old you can let fuel get before it's not safe to use in a Prius, Toyota Plugin Prius supposedly says in the owner's manual that you can go a year or longer with gas in the tank so... Whenever I see a plugin Prius at a gas station I ask the person when was the last time they filled the tank. Most of them say 6-12months.
    #4 PriusCamper, May 17, 2021
    Jim Swart and thetourman like this.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
    I just cracked open an original surplus jerry can that has a 1962 production date, which my dad acquired from a surplus store in San Diego,California in the early 1980's.
    We filled the can on May 2, 2011 with non-ethanol gas and Stabil.
    It had been stored in a shed 50 feet from our house.
    The gas remained clear with all of it's VOC's for over 10 years. I will eventually use it in my Prius v.
    Instead on filling, emptying and refilling many many times over the years, I prefer the fill and forget method.
    Metal surplus cans could be had for less than $15 each at that time in surplus stores. Even new ones were about $30 each, before the stupid C.A.R.B. spout requirement.
  6. Georgina Rudkus
    3,576
    2,603
    Taylors, SC
    These Midwest gas cans available at Harbor Freight is the best deal on the current variation of the original German jerry can.
    5 Gallon Jerry Gas Can
    I first bought them in 2008 and have more than 10 of them.
    They are made by Valpro in Europe. They are of the same high quality as the original German cans.
    VALPRO - Products - Metal cans - Progressive Line
    It's too bad that we are stuck with the plastic caps and C.A.R.B. spouts as the metal caps are not available in the US.
    Here's why you don't want to buy the cheap Made in China ones.
  7. fuzzy1
    10,710
    What do we know about Canadian rules and products, for those of us who hope to be able to cross the border later this year?
  8. rampante550
    rampante550 Member
    57
    35
    NC
    I'm doing a test with non-ethanol in my 205k 2012 Prius V (been in the teens overnight, highs mainly in the 30s and 40s).
    Baseline using 87 regular
    - 41.9 mpg
    - 42.1 mpg
    Two tanks since filling with 90 non-ethanol (lowest octane I can find)
    - 45.1 mpg
    - 45.5 mpg
    Not a massive uptick, but extra cost (about $.60 more per gallon) is offset enough that I'll continue to use it. I have an 06 Sequoia as well, I get an extra 30 miles per tank with it and feel like it helps keep the engines running a little cleaner on these engines as they age.
    Will follow-up when it gets a little warmer, hoping I get another 1-2 mpg more in both scenarios when we hit spring weather.
    PriusCamper likes this.
