Non-Magnetic Tranny Drain Plug - Did I Get Gypped?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Indy John, Dec 7, 2012.
  1. Indy John
    Indy John Member
    75
    33
    Indianapolis
    Being a DIYer and a keep-it-forever kind of guy, I dutifully drained and refilled my tranny fluid recently as I approached the 30,000 mile mark. To my surprise, the drain plug was identical to the fill plug - nothing magnetic about it. My '04 Gen II had a magnetic plug, from which I vividly remember cleaning quite a bit of metallic detrius.
    I guess I should visit a dealer and ask to see a tranny drain plug. If it's magnetic, I'll probably spring for one, but I can't help feeling a little cheated, and I'll be wondering over the next few years if should change the fluid "early" next time so that that plug can be replaced.
    Did anybody else find a non-magnetic plug?
  2. Former Member 68813
    3,524
    981
    US
    Funny, I did a search on it just a few days ago. I found one post stating magnetic plug was used in 3rd gen and some other poster didn't think so. We probably should set a vote on this.
    BTW, is the drain plug the same size as engine oil plug?
  3. El Dobro
    El Dobro A Member
    7,003
    3,226
    The drain plug in my '11 wasn't magnetic.
  4. Mendel Leisk
    38,957
    D.O., mine isn't either. I was a little disappointed.
  5. xliderider
    xliderider Senior Member
    7,901
    3,130
    Honolulu, HI
    You can buy a small neodymium magnet and attach it to your non-magnetic drain plug. Problem solved. ;)
  6. Former Member 68813
    3,524
    981
    US
    Wha
    What if that magnet decides to get attached to one of the MG supermagnets?
  7. xliderider
    7,901
    3,130
    Honolulu, HI
    I highly doubt the magnetic field from the MG magnets can overcome the force of the magnet clinging strongly to the steel drain plug from any kind of distance. It's not like the MG magnet is an MRI field magnet or something.
  8. gliderman
    gliderman Active Member
    751
    223
    Yeah... what if the MG supermagnets decide to repel it and it shoots up through the floor and lodges in your nasal cavity? :p
    BTW, my 2010 doesnt have a magnetic plug either.
  9. Former Member 68813
    3,524
    981
    US
    Is it supposed to be funny?
  10. El Dobro
    El Dobro A Member
    7,003
    3,226
    Sounds like it. Anyway, just stick the magnet to the outside of the plug, it'll work.
  11. Former Member 68813
    3,524
    981
    US
    I'm thinking about drilling the plug slightly and gluing the magnet into the cavity with epoxy.
  12. Mendel Leisk
    38,957
    El Dobro's stick-it-on-the head-of-the bolt seems quite effective.
    I picked up a packet of 4 rare earth magnets, about 9/16" OD by 1/8" thick, advertised as having 8lb lift capacity, for around $7.
    Putting one on the head of a scrap bolt, I was able to easy lift up a swiss army pocket knife, with the tip of the bolt. I put one on the heads of both the drain and fill plugs. You could periodically remove and clean the fill plug.
    The only downside: to remove the transaxle bolts you need to temporarily pull the magnet off to break loose the bolt with a 10mm hex insert, demagnetizing the bolt (though it might retain a bit of magnetic attraction, having had the magnet on for some time). Then you can replace the magnet before spinning the bolt out by hand.
    Brain wave: put one on the engine oil drain bolt too! A 14mm socket did fit over that magnet, but you want to leave the socket on the bolt head when removing, it tends to stay with the socket.
    WE0H likes this.
  13. El Dobro
    El Dobro A Member
    7,003
    3,226
    I use magnets on the shafts of screwdrivers to hold the screw onto the end so I can get them started in the hole.
  14. manza
    manza Junior Member
    I am ready to do my first replacement of the CVT fluid. Do the drain and fill plugs have gaskets? Thanks.
  15. Mendel Leisk
    38,957
    Yes. Both are the same.
  16. manza
    manza Junior Member
    Thanks.
  17. Bill Norton
    Bill Norton Senior Member
    1,882
    617
    MONW, Ks.
    The magnet I used was purchased at a "Science Supply" store. You know the kind for kids and school projects?
    This is definitely an improvement over nothing.
    I used a little sealant just to aid in cleaning it.
    See my post on ATF analysis. It was horrible.
    I will post a picture of the magnet after 10k miles also.
      File size:
      3.4 MB
      447
