Non-Professional Photos of 2010 Prius Thread.
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Rybold, Jan 14, 2009.
  1. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    Are we still fixated on whether a windshield produces upforce or downforce? I'm going to have to side with Patsparks and qbee42. The windshield does not generate lift. The Prius body as a whole does generate some lift, albeit an insignificant amount. It just can't go fast enough for that lift to have any effect. And again, no need to worry ... the weight of the Prius will keep it on terra firma.
    Now, auto racing engineers and drivers do need to consider lift and downforce, especially for traction while cornering and to minimize brake wear. Here's a good read:
    The Physics of Racing
  2. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Thanks. If you've derived the equation, then I believe you. From the very beginning of this thread, I would have agreed with you that the overall shape produces a positive amount of lift, BUT a MINIMAL amount of lift. Yes, I agree with you that it produces a minimal amount of lift, but I think many other people here think it produces a more significant amount of lift. Consider this computer generation on the NASA website of an [ideally-shaped airplane wing; the Prius is not an ideal wing; in fact, driven backwards, the Prius would be more like a wing] - when the span is reduced from 100ft down to 5ft, the amount of lift decreases SIGNIFICANTLY. (scroll down) http://www.grc.nasa.gov/WWW/K-12/airplane/size.html
    Second, since the Prius is so low to the ground compared to an airplane wing, I'm sure the lack of air below the Prius hinders the efficiency of air underneath providing lift. Also, notice that an airplane wing is the shape of a sphere (basketball) on the leading edge; directing and equal amount of air to the top and bottom, whereas the Prius directs almost all air to the top (and some to the sides). http://farm1.static.flickr.com/186/437187264_f154eee3a8.jpg?v=0 (It looks like a wing, until you actually put it next to a wing. Then you see the difference)
    NASA: "NOTICE: The upper and lower surfaces of the Wright airfoils are nearly the same length; the lower surface is not flat like many modern low speed airfoils. This is a perfect example which shows that the popular theory of lift generation found in many textbooks is completely wrong! The upper surface doesn't have to be longer than the lower surface to generate lift. The lift occurs because the airfoil turns the flow of air and both the lower and upper surface contribute to the turning." bottom of the page, http://wright.nasa.gov/airplane/geom.html
    Explanation of how lift is generated (I don't see this in the Prius, yet I definitely see it in commercial aircraft wings) http://wright.nasa.gov/airplane/lift1.html Image and computerized simulator: http://wright.nasa.gov/airplane/shape.html
    (There's a link to a video of "Orville and Wilbur" (actors) where one is carrying a piece of flat plywood while the wind is blowing and he notices that depending on how he rotates the flat piece of plywood, the wind pushes it up or down. That would be what I'm referring to when I talk about the windshield on a car. Yes, the Bernoulli Effect produces a small amount of lift on the trailing side of the car (rear windshield), but I think the wind against the front windshield also pushes downward. Note that in the simulators and photos of airplanes sitting on runways or flying, the wing is not horizontal; it is at an angle with the leading edge higher than the trailing edge. This is because, in addition to the Bernouli Effect, the wing also makes use of the "flat piece of plywood" concept. It is when you have a combination of both, that sufficient lift occurs.
  3. drees
    drees Senior Member
    1,782
    247
    What do you consider "minimal lift"?
    The Prius probably generates around 100 lbs of lift at highway speeds. Those lift numbers will likely double or more in cross winds. I'd also guess that the Prius generates significantly more lift than your typical car because the roofline is so smoothly rounded. This seems to be verified by how easily the Prius seems to drift in cross winds.
    Unfortunately, until someone who has put the Prius in a wind-tunnel reveals their data, we'll all just be guessing.
  4. Rybold
    2,760
    322
    Southern California
    If the entire vehicle, as a whole, only produces 100 lbs of lift, then I would agree that is "minimal" in my view. I notice that you used the word "guess" numerous times. So, here's what I'm thinking at this point: The entire Prius produces ~100 lbs lift (guess), yet the windshield pruduces ~100 lbs of downforce (the "plywood effect" on NASA's website; if you have a flat horizontal piece of plywood and the wind is blowing, and you rotate the piece of plywood it will have lift of push downwards. We've all experienced this, whether it be plywood or a piece of posterboard or a manilla folder).
    If no one has any strong objections, then I'd like to stick with this understanding. I looked at quite a bit on NASA's website (links above), and I feel very confident in my understanding.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    :focus: This entire conversation is worthy of it's own thread!
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    What he said :D
  7. drees
    drees Senior Member
    1,782
    247
    OK...
    Yes - I am guessing based on the other wind tunnel numbers I've seen for other production vehicles. They all show lift at the front AND rear of the vehicle. The only ones that don't are sports cars which large spoilers/wings on them.
    Dude, the windshield is no piece of plywood. There is a curving hood at the front, a curving roof behind it and underneath is a big jumble of a mess of parts along the underbody. On a "conventionally" shaped car - yes - there is often a high pressure area at the base of the windshield. But the Prius is not a conventionally shaped car. The whole thing from hood to trunklid is one carefully rounded shape.
    And either way, you can't simply take the windshield and say "it produces 100lbs of downforce". It's the combination of parts on the whole vehicle which result in up/down force.
  8. patsparks
    10,664
    567
    Adelaide South Australia
    going on the premise that the windscreen produces down-force while the roof produces lift, convertible cars must feel like they are glued to the road with the roof down at speed.
    We do seem to have hijacked this thread, feels like something familiar to me.
    I vote that this should be the last post about aerodynamics of the Prius on this thread giving me the last word.
  9. carz89
    444
    47
    San Diego
    I agree that you should have the last word!
  10. patsparks
    10,664
    567
    A non-professional photo which demostrates the extra space in tha back.
    Note legs almost flat across floor and only head would prevent the hatch closing.
    Lots of room.
  11. carz89
    444
    47
    San Diego
    Those are tempting words!
  12. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Wait, I think we had this conversation before...
    :focus:
  13. patsparks
    10,664
    567
    And the hatch got closed. :(
    Maybe next time it will prevent the hatch closing.
    Oh I found a little snippet after being directed there by another thread for another reason, sorry to take this there again folks.
    http://www.nytimes.com/2008/12/21/automobiles/21AERO.html?_r=1&scp=1&sq=aerocorner&st=cse
    An interesting read all the same.
  14. Rybold
    2,760
    322
    Southern California
    Well, shoot! If you have empirical data, you should'a said so five days ago! (I'll take your word for the data) Thank you for finally adding this information. :)
    Very true. I agree.
    [[ Case closed ]]
    :focus:
  15. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Wait! As long as all the aerodynamists are focused on this thread, I'd like to hear their opinions on whether and how the slightly altered shape and new ridges on the Gen 3 might affect cross wind stability. I mean, .25 CD is great and all, but how slippery is it to cross winds? Some people used to speculate the somewhat tall slab sides of the Gen 2 (on such a light car) contributed to the highway stability problems.
  16. HTMLSpinnr
    5,341
    920
    251
    If you all wouldn't mind carrying the Aerodynamics to a dedicated thread, thanks! Feel free to link it here. :focus:
  17. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    I would guess (since I don't have enough data) that it should be somewhat improved over G2 in crosswinds, by virtue of the side cross-section having its center of area somewhat further to the rear. this means that the Center of Pressure is further behind the CG, which is where you want it to be; since any lateral disturbance will then self-correct towards the direction of travel.
    I know some people here have commented on the Prius lack of lateral stability, though personally I don't think it is that bad. Certainly not as bad as the old VW bug, where the CG was further back than normal, thanks to the rear engined arrangement. Also the lighter the car, the more it is going to be affected by side gusts. And the Prius is a relatively light car, as was the rear-engined bug.
    It would be interesting to know if Toyota did any W/T tests on lateral stability; they obviously did drag measurements, to derive the Cd values of 0.25 they quote.
  18. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I dont know if this forum software allows for it, but can a moderator split selected posts from this thread (all the aerodynamic ones) and put them into their own new thread? I know phpbb allows one to do it. It doesnt seem the aero talk people want to start a new thread discussing the topic. ;)
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,077
    Northern Michigan
    Correct. Moving the center of effort aft does not reduce the sideways forces, but it does make them self correcting. A just from the side causes the rear end to shift away from the just, much like a weather cock.
    The reduction of Cd on the Gen III Prius comes from a large number of small improvements. The major ones are a more streamlined underside, ridges on the front corners that move the airflow away from the front wheel wells, and improved wheel well and air dam shape. Many other areas of the car were tweaked slightly, all with an eye toward improved Cd.
    Tom
