Non-running Prius. Good Buy or Not?
Discussion in 'Gen 3 Prius Main Forum' started by Colton Campbell, Feb 18, 2020.
  1. Colton Campbell
    Colton Campbell Junior Member
    Saint Joseph, MO
    New to forum. I'm a 34yr old Toyota guy. I do my own maintenance on our 06 Tundra, 05 Sienna, and 09 Corolla. Every now and then I browse the vehicles for sale in my area to see what the market is like. I ran across this:
    2010 Prius. Black exterior. Grey leather interior. 155k miles. Non-running and he's asking $3,000. He doesn't want to mess with it. Vehicle was being driven and then died. Driver pulled over to the side and had it towed to his garage where it has sat for more than three months. The guy is from Sudan and not mechanically inclined. (I don't profess to be a pro either, but I DO love saving money by doing everything myself). I'm only the second person to have ever gone and see the car(which aesthetically is in GREAT shape) because the owner had no pictures in his listing.
    I brought my little jump starter battery pack with me, a multimeter, and my BLUE DRIVER OBD II scanner when I went to look at it. The 12v battery had only 8.8V when I first measured. Once I put the jump starter on the correct terminals, I was able to get the 13v needed to the car, and was successfully able to get dash lights and the car into Neutral position, but was unable to jump-start the car. Guessing the traction battery was dead, I assumed the car engine would turn over to remedy that but it didn't. Dash says "Check hybrid Battery" which I also believe is displayed even when the 12v battery is dead. There was the yellow triangle on the dash, and the check engine light, but I couldn't see any codes on my obd scanner! (Maybe my Blue Driver just doesn't work..i'll continue reading the forums for proper tool). I pulled the car fax on it. It was taken to a toyota dealership in Oct of 2019 where I did verify they checked the hybrid battery tested good. This service check was just before the car died on the side of the road.
    My gut feeling is this is a simple fix really, I just don't know what it is. $3k is a steal for this car from what I can find online in my kansas city area, and it would be a sweet upgrade from my Corolla. I want to jump on this but am looking for that "fatherly consent" from any other prius owners out there. If majority believe it could be something serious (i've read piston rings can go bad on 2010 models), I'll just be patient. Your thoughts? Jokes? Favorite cookie? :D And if I DO buy it, I'm most certainly going to share the experience on here for future data collection.
    Johnny Cakes likes this.
  2. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    Seems like many early Gen 3's suffer from burning oil. Also Head gasket failures tend to show up as the mileage climbs. Consider that an engine replacement might be the reasonable need if it turns out to not be a simple option. The fact that he had it to the dealer to check the hybrid battery makes me feel like it is a more serious problem. I also expect that if he had the car towed to his garage and he is selling the car rather than getting it fixed further adds fuel to my belief.
    I would think that 3,000 is too much for a '10 with 155,000 miles and not running. I will let the others come up with an amount they think might be fair as there are several posters on here that have recently been in your shoes and would be better informed,
    Maybe the garage would tell you what they feel is wrong and give you a ball park idea of what they would charge to fix it?
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    kc5dlo and Raytheeagle like this.
  4. RunningOnMT
    RunningOnMT New Member
    Bozeman, MT
    If you look at the repair costs for each of the potential causes of the "not running" issue, and compare that to the delta between the cost of the vehicle you're looking at and a running example with similar miles, you may get a better sense for how much of a bargain it is or isn't.
    My concern would be that the hybrid battery issue is a red herring. Could the original issue be something like the engine seizing, and the hybrid battery failed from sitting? Maybe, maybe not, but I like to price in the potential for nasty surprises if possible.
    Prices do vary regionally. Up here, a running 2010 with similar mileage goes for $6.5-$9k depending on how optimistic the seller is feeling. I got a 2011 last summer with 139k for $5500 that needed nothing but a good cleaning; that was a steal as far as I'm concerned, and if I'd had to throw a couple grand in parts into it due to some issue I didn't detect at purchase I'd still have been ok.
    The key with a project is to have wiggle room to deal with surprises. The less you know about the extent of the problem, the more wiggle room you need. For me personally, I'd be much happier to be at or under $2k.
    Also, from what I've seen a 2010 is the least desirable of the 3rd gens. FWIW.
    kc5dlo likes this.
  5. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    I agree $2k or less not knowing what the problem is....also, sitting unused shortens the life of the hybrid battery so add in the fact that it has been sitting 3 months already and who knows how much longer while being repaired?
    Good luck with your decision!
    kc5dlo likes this.
  6. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    You cannot trust your gut on this car, and you can't get good data until you get it started.
    I'd say $2K as is.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    As @JimboPalmer suggests, plug in the VIN number and see what you find.
    I'd be curious what recalls have been done, as if J0V or previous inverter recalls have not been done, it may explain the original issue.
    Now that the car has been attempted to start several times, I'd be concerned about the hv battery state of charge.
    Good luck and keep us posted(y).
  8. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Read the car's OBD-II data using an app to see what state the HV battery is. It might be empty, it might be toast, it might be perfect and there's some other problem, but without checking you'll never know.
  9. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    There's something more to this story, IMO. Just a hunch...maybe it was towed to a local independent mechanic and the diagnosis was bad. Owner had it towed home because he didn't have the budget to repair it at that time. After 3 months of not finding a good solution involving used parts and DIY, he's giving up.
    I don't think I would buy it without knowing exactly needed to be fixed, especially because it's a 2010. (2010 seems to be the most troublesome year for the 3rd gen.)
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Definitely use an app like Torque Pro or Dr Prius to figure out hybrid battery condition.
    If it is too low you are going to need to try to charge it up.
    Which will cost money to buy/build a charger.
    Or perhaps hybrid battery is bad.
    That can be a $2500-$3,000 expense for a new one.
    Or if you have lots of time, are willing to learn about batteries, buy equipment, and don't need the car to be super reliable, you could pick away at it $50 at a time for modules.
    If the guy gets rid of the car to scrapper, he will bet $250-$500 max.
    I would really want to know how/why it stopped working in the first place.
    Blown head gasket?
    Drove it without oil?
    Inverter pump died?
    Inverter itself died?
    Transmission shorted out?
    Thrown rod?
    Broken piston?
    etc.
    All these things are possibilities.
    Unknown, non-running Prius? Definitely less than $1,000
    Spend whatever money you are willing to throw away in case you end up buying a lawn ornament.
    I'm usually only up for a gamble if I can do a bunch of diagnostics first.
    Once I have a pretty good idea what I'm dealing and I feel like it is worth the work, then I'll pay a bit more and roll the dice.
    Else move on to a running car. Or one that I can get more background on.
    Feel free to call if you want to chat about what to look for to limit your exposure. 608-729-4082
    I work on hybrids for a living.
    Bay Stater, pjksr02, RMB and 2 others like this.
  11. Colton Campbell
    Saint Joseph, MO
    Fantastic support! Thank you all for your help.
    1. J0V - UPDATE PWR MGMT & MG ECUS - DONE on 4/24/19 -pulled from Toyota website. Multipoint inspection done but no extra notes.
    2. On 10/18/19- the car was taken to a 3rd party semi-large auto shop. Engine/powertrain computer/module checked. I called that business and they shared that they checked the hybrid battery bank-and it tested fine. All they did was replace the 12v battery. He drove the car for 10 days he said with the new 12v battery then the car failed and he pulled off the road. Towed to buddies storage.
    3. According to the carfax, the oil has been changed every 10k-ish miles. Sometimes 7k miles between changes.
    I'm comfortable changing out the hybrid battery myself if it comes to that.
    Not much other background yet on the vehicle. The guy is really nice, but from Sedan. His English is hard to understand and his vocabulary is limited. Next time I talk to him, I'll ask him pointed questions about what he felt/heard when he pulled over on the side of the road. He is no mechanic. He has no tools or experience. The car WAS taken and dropped off at one of his friend's properties which is a garage. But the business doesn't look like it's been "in business" for some years as there are holes in the roof. Basically it's a storage building for 'stuff.' Lots of other things besides a few cars in the garage. I'm guessing it was just a space to store it as the owner lives in an apartment. He originally purchased the car for $7k back in 2018. Running, the car estimates value at $7-8k on edmunds/kbb n' such for my zipcodes.
    From your comments:
    1. I'll need to sit there while the 12v battery charges. I have a car charger, and thankfully there is power in the building where the car sits.
    2. Once battery charged up enough, plug in Blue Driver OBD scanner, and use Dr. Prius app to check status of hybrid battery.
    3. If dead, shouldn't the car recognize this and start the engine to charge the traction battery?
    4. But since there is the yellow triangle on the left side of dash, i'm assuming the car won't start anyway. I'll check for codes again, clear codes, then unplug 12v battery from car for a few minutes. Reconnect battery and try to start.
    Out of time for now, and I'll report back. Thanks guys!
  12. Colton Campbell
    Saint Joseph, MO
    Update:
    I finally got to speak with service dpt of Toyota dealership that did service on the 4/24/19 date. They indicated from the multipoint inspection that just several bulbs were burnt out(typical), and recommended fluid changes of engine coolant/brake fluid change...basically the typical maintenance schedule items. They noted there was nothing wrong with the car at the time.
    I followed up with the owner. I asked him about the experience of when the car died. He said that he saw the yellow triangle and took the first exit closest to him. Once pullled off into a parking lot, he then had the car towed. He confirmed that there was no vibration, engine knocking, no high temperature lights or anything of the sort other than the yellow triangle light. He said his last oil change he did at 3k miles. I'm headed over today after work to do the battery charge up and see if I can read some codes.
  13. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    If Hybrid battery is too low it won't be able to start the car and therefore it cannot self charge.
    The codes will hopefully help determine where the problems are.
    Also, hopefully you can see if section(s) if the hybrid Battery are damaged
  14. Colton Campbell
    Saint Joseph, MO
    Just checked out the car again tonight.
    12v battery voltage prior to charging: 8.24V (oddly low..more later)
    Attached my car charger. Normally it would show it's applying 14V to a 12V battery while charging. It only showed 11.3V.
    I left it charging till the charger indicated the battery was at 62% charged. it never went past that point. Also strange. There were no codes at all except that the Dash monitor indicated still "check hybrid system."
    After 20 min of no change of battery charge state, I unplugged the charger, and disconnected the 12V battery from the car for 2min.
    Upon reconnecting the 12v battery back up, I reconnected my car charger and this time set it to "start vehicle." The yellow MIL triangle was off! The charger showed applying 17V(normal for this charger in jump start mode). I went to start the car. The engine turned over for like 1/2 second! But didn't turn on. Turned car off. Tried to start it one more time, and still, it acted like it wanted to, but felt like it was just too sluggish to continue turning over enough to get the motor running. Yellow triangle MIL light re-appeared and wouldn't turn over after that. The 12V battery never read more than 11.3 volts even after charging. I just don't think a 6 month old battery would read 8v initially unless there was a bad cell. Just really strange. "check hybrid system" was back as well.
    The guy agreed to take the 12v battery back to Toyota dealership to get tested for bad cell (84 month warranty). In about a week I should get the new OBDII blue tooth dongle that will sync to Dr. Prius app( as the BLUE DRIVER dongle is proprietary..bleh) and then check the hybrid battery sections as suggested.
    Learning here. I've read that it's not the 12v battery that starts the motor, but the actual hybrid battery. If the hybrid battery is toast, it can't turn the motor over. So I guess options are charging hybrid battery(i'll have to look into that on other forum posts here), replace hybrid battery? There's no other way to get the motor on?
  15. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Be very, very careful on trying to start the car too many times.
    You generelly have 5-10 attempts before you drive the hybrid battery way too low.
    You can access data about the hybrid battery, etc without starting the car.
    Put a charger on the 12v. Or buy and iunstall a new one.
    Put the car in IG on, but not Ready. (WITHOUT pressing the brake, press the power button 2 times)
    Using your OBDII adaptor and software, get the battery data and post it here.
    - Hybrid battery State of Charge
    - Battery Bloc voltage for all 14 blocks
    There isn't any other way to get the motor on without a healthy hybrid battery.
    Seriously, don't try starting it any more until you post those pieces of data.
    then, when you go to start it, do a bit more preparation in order to increase your possibility of success.
    Some ideas....
    - remove and clean throttle body
    - sop up any additional oil from the top of the intahke
    - clean the Mass AirFlow sensor (MAF)
    Reassemble things
    - have some starter fluid ready to put down the throttle body when starting the car.
    Colton Campbell likes this.
  16. Colton Campbell
    Saint Joseph, MO
    Final update: Seller won't sell less than 3k regardless. My obdii dongle hasn't come in yet that will work with Dr. Prius app. After speaking with the wife, we've decided to postpone getting this one and wait for another deal down the road. Thanks all for your help. I've learned a lot already just from reading various posts in this forum and will be more prepared for the next Prius down the road.
    Bay Stater, RMB and kc5dlo like this.
  17. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Plenty of other deals will come along.
  18. Serenity
    Serenity Junior Member
    23
    San Antonio
    I was starting to worry you were going to get it working, then he would decide not to sell it.
