non smart key fob draining battery
Discussion in 'Gen 2 Prius Technical Discussion' started by gptoyz, May 12, 2026.
  1. gptoyz
    gptoyz Junior Member
    85
    17
    los altos
    my friends Prius only has 1 key left, it drains the battery like within 1 day (using Duracells) what's the best way to fix this?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,133
    6,982
    Texas Hill Country
    Partially depends if its a wireless smartkey or a traditional insertable key.
    Either way I would immediately go to a good locksmith (save a few dollars) or the dealer. When your key fails it is more expensive to replace and you are likely to need a tow.
    Having two is always smarter. If you lose the only one that works its the same more expensive situation.
    #2 rjparker, May 12, 2026
  3. gptoyz
    85
    17
    los altos
    it's the insert style key, not a smart one
  4. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    My guess would be that one of the buttons is sticking in the 'on' position intermittently.
    I wouldn't waste any time getting a second fob, as RJ suggested above.
