Non-typical engine shudder cold or hot - no error codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ProblemPrius, Jun 5, 2023.
  1. ProblemPrius
    ProblemPrius New Member
    2013 Prius v wagon
    Hello, I'm having a problem with my 2013 Prius v Five with 147k miles.
    Long ago (around the 100k mark) about every 50 or so cold starts the engine would shudder violently for 5 to 10 seconds and then smooth out. Slowly over time the violent shudders increased in frequency to about 1 in 10 cold starts. But last night, with the engine fully warmed up in 60 degree dry weather, after driving for about an hour the engine started to vibrate violently in stop and go city traffic, whenever the engine would turn on from all electric mode. I temporarily solved it by putting the gear selector in "B" mode so the engine stopped shutting off and the shudder did not occur for the remainder of the trip.
    Since the shuddering started about 50k miles ago, I have had to add about a 1/2 gallon of coolant. However there is no noticeable white smoke from the tailpipe and no noticeable moisture in the oil, but could a blown head gasket still be a possibility?
    Also, as far as I know the EGR has never been cleaned.
    Looking at this forum it looks like the problem could be any one of about a dozen things from a dirty EGR, to a dirty PCV, to a dirty MAF sensor, to the wrong octane gas (I typically just use Shell 87), to water in the gas, to coolant needing a flush and fill, to a bad water pump, to a bad motor mount, to failing coil, to a fouled plug, to a bad coil wire, to a to blown head gasket!
    Can anyone recommend the diagnostic steps you would begin and follow with in my situation?
    ukulelegeek likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,071
    5,306
    Pacific Northwest, USA
    Atkinson engines act up like this occasionally even when there is nothing wrong... An EGR cleaning could help... Main thing is when this symptom happens more often and you start loosing engine coolant, it's early sign of blown head gasket which is common with Gen3 Prius.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    blown hg due to coolant loss
  4. Brian1954
    Brian1954 Senior Member
    2,410
    967
    South Central PA, USA
    Grit likes this.
  5. ProblemPrius
    2013 Prius v wagon
    Thank you for the responses. Definitely not what I was wanting to hear. But it is a bit confusing. Why would the engine shudder repeatedly going from electric to engine after the engine was fully warmed up and not produce any smoke whatsoever if it is the head gasket? And if it is the head gasket why when I went to start it up this morning there was no shudder and as usual no smoke? It almost seems like an electrical malfunction to be this random. But if it was I suppose it would produce a code, but as yet, no light on the dash and no codes when I read the OBD with the Torque app.
  6. bisco
    52,395
  7. ProblemPrius
    2013 Prius v wagon
    Thanks, I'll give it a try...
  8. rjparker
    rjparker Tu Humilde Sirviente
    10,526
    6,608
    Texas Hill Country
    yes
    I would bet $1000 on the head gasket which has progressed to severe. The first few months it was sealing the coolant leak as soon as it warmed up. The fouled plug cleared and all the egr / cold start condensation theories felt good.
    Now it really needs a complete rebuilt engine.
  9. ProblemPrius
    2013 Prius v wagon
    I am not up to doing a head gasket myself. I have been calling around local shops and no one wants to touch the Prius hybrid engine except Toyota dealerships! I'm waiting to hear back from service managers at two dealers, but so far one dealer quoted me a price of $4,200! They said it is a 20 hour job.
    Can anyone recommend a shop in the Central-Maryland / DC / South-Central PA area?
    Or maybe I should look a rebuilt engine?
  10. rjparker
    10,526
    6,608
    Texas Hill Country
    Rebuilt can be less than a dealer hg job. But you need to find a shop that will swap it. Changing a Prius engine is really no different than a non hybrid except they have to remove the inverter assembly, maybe a thirty minute or less job for the uninitiated.
    Skilled shops can swap the motor in less than eight manhours. There is a video of Gasketmasters doing it in one hour with two guys.
  11. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Replacement of head gasket on these is no different to none hybrid gasket replacement
  12. ProblemPrius
    2013 Prius v wagon
    Thanks all for the advice. I decided to go with a JDM engine from eBay that has less than half the miles of my 147k engine. It was just delivered today and it looks nice with one exception: the flywheel has some light surface rust (perhaps got rained on?). If this thing was left out in the rain will that cause any problems? Should I put my old non-rusty flywheel onto the new engine?
  13. Stephen Herman
    Stephen Herman Junior Member
    16
    North Carolina
    To confirm head gasket could do overnight pressure test of coolant system (any dealer should have equipment) no visible leaks but reservoir lowering, then yep its the head gasket.
  14. ProblemPrius
    2013 Prius v wagon
    Long time since an update: Got the engine in and it runs great. A little more power and no more shudder. But now I got a totally new problem... the notorious ABS issue which Toyota refuses to cover. I'm going to post a new thread about it.
  15. Mendel Leisk
    41,911
    Did you clean the intake and EGR components?
  16. ASRDogman
    ASRDogman Senior Member
    7,828
    3,986
    Glad it's working.
    Did you have the ABS issue before installing the engine? If not, you should check
    all the connections and make you didn't forget to connect something... or disconnected...
