Featured Non-USA Hybrid Minivans
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 24, 2017.
  1. bwilson4web
    16,495
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I've always thought the 6 passenger Mazda 5 model (truly a mini-van) would have made a great HEV/PHEV platform; basically the specs of the v but with sliding rear doors and more headroom for the mid & rear seats.
    52,693
    how's the pacifica working out?
  4. Trollbait
    12,787
    Last I looked into the Estima hybrid, it was between the Sienna and Mazda5 in size. If that is still the case, then the Americans that still buy minivans will not buy these hybrids.
    The HSD used in the RX should work in the US Sienna. In the past, I think such a minivan would have been overpriced for the fuel economy improvement. That may have changed now that Toyota is offering multiple trims of the Highlanderh.
    Looking at the curb weight, I don't think the Accord hybrid system will work well in the US Odyssey as is.
    The real issue though, is that the minivan market is dying. GM and Ford have been out for awhile. The Mazda5 is gone, and Nissan stepped out this year. FCA, Honda, Toyota, plus Kia are all that is left. If the trend continues, Kia will be the next to drop out.
    austingreen and fotomoto like this.
  5. austingreen
    austingreen Senior Member
    13,712
    4,231
    Austin, TX, USA
    1) People normally buy minivans for low cost versus SUVs and crossovers. A van would make a great phev. A minivan - well no, simply because people won't pay the price.
    2) Put somthing like the 2018 camry hybrid system in and maybe it works. You probably need a bigger mg2 and larger more powerful battery since it is a heavier vehicle, but mg1/hsd/etc could work as long is the price is low enough.
    3) seriously what you want is a crossover 7 passenger phev, built from the ground up. Its going to be expensive, so might as well put at least 7 kwh of batteries in it and a turbo 2L that can run miller cycle (or one of those new supercharged hcci mazda engines) and make the thing aerodyanmic but comfortable. That sienna starts 1200 lbs heavier than a camry. You probably are going to do a steel/aluminum treatment like tesla is doing with the model 3 to save weight, and build the battery into the chasis so it doesn't take up any interior space. Superefficient locked overdrive miller cycle on the highway, batteries for acceleration and city driving.
    Compare Side-by-Side
  6. hill
    9,001
    iirc, the parent company is Fiat. So, at least ONE foreign (plugin !!!) hybrid minivan gets sold here in the usa.
    ;):D
    humor aside, as younger folk, we used to say FIAT was an acronym for, "fix it again, Tony".
    Lo & behold, the plugin has already been hit up for a recall;
    2017 Chrysler Pacifica Hybrid plug-in minivan recalled for faulty diode (updated)
    what a drag - having to bring in a car for repairs so early in the game
  7. Tideland Prius
    16,658
    The Estima is too small for the American market (at least the modern American market) but I believe the improvements made to the Gen 4 can make for a viable hybrid minivan. 32mpg is the target (ok the Pacifica has a bigger battery but still, nothing wrong with aiming high).
    The question is: Is the 2.5 litre Dynamic Force engine and HSD combo in the new Camry (208hp) enough to carry 7 passengers, luggage and the weight of a minivan?
    Or does Toyota have to resign to using the 3.5 litre HSD setup (which may also get improvements.... we'll have to see what they do with the HiHy and RXh).
  8. hill
    9,001
    resign ? iirc the 3.5L hyhi is already improved ... now over 300hp as well as higher epa ... 29mpg blended & 30 city? Slap a Pacifica sized traction pack in that sucker & ...... lookout!! If parent company Fiat can get credit for the amazing Pacifica stats, then Toyota ought to be able to follow suit, if not better it. It's only sad that they didn't do it 1st.
  9. Tideland Prius
    16,658
    Well I'm assuming they're going the hybrid route and not PHV hence the assumption that they'll try to use the 2.5 HSD if possible to get better mpg if the performance is adequate.
  10. hill
    9,001
    Don't forget what happened to the first generation volt when they tried to go skimpy on the ice.
    Prodigyplace likes this.
  11. Tideland Prius
    16,658
    Again, last I heard (and this was several years ago now), they didn't achieve the performance they wanted with the current gen Sienna. Didn't say if they meant underwhelming power with the 2.4 HSD (or 2.5 HSD) or whether the mpg gain with the 3.5 HSD wasn't large enough.
  12. hill
    9,001
    Well you WERE spot on - years ago, when i 1st lamented the notion a plugin Prius v would not come about, & you corectly pointed out the frame was just too light to properly support such a build - between all the competing safety / suspension / power issues. so from that, one easily can glean that weight & power serves a valid interest in range/efficiency increases.
  13. Trollbait
    12,787
    There is that new RWD hybrid transmission in a Lexus. I suspect its intended use was for a truck, so it might work well in a heavy minivan.
  14. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Stylistically everyone (except me) rejects wagons and minivans as out-of-style in favor of SUV format.
  15. Tideland Prius
    16,658
    Multi-Stage Hybrid? If the rumours of a RWD-biased Pilot or Odyssey hybrid are true then maybe Toyota could. But you would think packaging would favour a FWD minivan (so that you can have your fold-into-the-floor seats)
  16. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Estima/Privia hybrid is not going to cut it in the US. You need to bring the Toyota Alphard Hybrid to the US. It may be ugly as hell but it's the closest size to the Sienna and probably more luxurious.
  17. bwilson4web
    16,495
    I think there is a market for a utilitarian micro/mini van:
    • VM MicroBus
    • Scion xB (original)
    For us, the BMW i3-REx is the close enough that I am using it more frequently than the Prius Prime.
  18. Trollbait
    12,787
    Perhaps it can be packaged for FWD.
    I thought the fold in the floor seats were FCA only, because of patents.
    It's a small market though. We might see an EV Microbus in the future, but the xB became Matrix sized, and Mazda5 was cancelled due to low sales.
  19. Tideland Prius
    16,658
    It'll be a different system but if they really wanted to, I'm sure they could. Might be a hard business case to sell to the boss.
    Yeah I think that's just the "Stow n' Go" seats for the 2nd row. Practically everyone else has the 3rd row folding into the floor. (Sorry I was thinking 3rd row when I made that comment).
  20. austingreen
    13,712
    4,231
    Austin, TX, USA
    Odyssey hybrid if they build it, will be based on the accura mdx hybrid - fwd engine with electric motors in the front and rear - similar to the Lexus RXh.
    Still cost and mpg from a big v6 hybrid is not that great. Perhaps to keep costs down a 2L turbo 4 running the miller cycle and simple hsd like the camry system (more powerful battery and mg2 to provide enough torque for the added weight). Still I think that phev is probably the way to go on a minivan - but sales of the pacifica phev are not great.
    You mean like this?
    270-Mile All-Electric VW I.D. Buzz Is the VW Bus Reimagined
