None ABM or Flood battery on Prius?
Discussion in 'Gen 3 Prius Main Forum' started by Tekken, May 23, 2021.
  1. Yaesu
    Yaesu Member
    111
    34
    Kentucky
    When the OEM, AGM battery failed I found someone to jump start the vehicle directly on the battery. I drove the Prius home (about 50 miles) and the smell of H2SO4 was very strong. I have used many AGM batteries in vehicles that weren't designed for an AGM battery and several failed within a few years. I wonder if the slightly different charging profiles affect battery life.
  2. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    AGM normally needs 14.7V instead of 14.4V.
    If you never charge it with the correct voltage the battery will lose capacity.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,802
    2017 Prius c
    No sorry but it won't "Lose capacity".
    Unless you define that to mean that it only charges up to maybe 97% of capacity instead of 100.
    A slower charging rate tends to extend life, not diminish it.
  4. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    slow charging seems work better on AGM battery. Slow charge about 1amp on my old AGM battery for overnight and last 5-7days.
