Normal noise from brake master cylinder/ABS unit?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by phobix, Apr 19, 2014.
  1. phobix
    phobix Junior Member
    22
    Montreal
    Hello Everyone,
    I have leased my 2012 prius since April 2012 and about a year ago I began to notice the following noise originating from the master cylinder/ABS unit. The noise happens if I push the pedal firmly to the floor and occasionally during regular braking. The braking system seems to be working fine and regen braking is functional. I am wondering if this noise is a sign of an imminent failure. The reason I am asking is because I just decided to buy back the prius off lease and I still have factory bumper to bumper warranty available and have heard horror stories concerning the cost of a replacement ABS unit on the Gen III Prius.
    Listen to audio recording
    Video version here:
    WeVideo
    Thanks in advance
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I believe there is a TSB for that. Someone will come along shortly and point it to you. Or search.
    phobix likes this.
  3. JC91006
    16,936
    8,647
    This sound you are describing is brake actuator noise, all prius cars make this sound. If there is a problem, you would have a dtc or dash light to warn you the system has a fault.
    The was a recall on early 2010 models to replace the brake booster, but no recall on 2012 models
    SM-N900P ?
    phobix likes this.
  4. phobix
    22
    Montreal
    This is certainly reassuring to hear that this is a normal noise. Did you actually listen to the recording? I used my iphone and had it placed adjacent to the ABS unit while my wife was pushing on the brake pedal.
  5. JC91006
    16,936
    8,647
    I was going by your description only, I need a computer to hear the sound.
    SM-N900P ?
  6. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Went to listen to it but requires a download. No thanks.
  7. phobix
    22
    Montreal
    As an IT professional I should know better, I completely understand your concern. I will embed a YouTube version of the audio clip a little later this evening. Thanks for your input
    edthefox5 likes this.
  8. PriusInParadise
    180
    91
    Hawaii
    It is the normal sound of the brake hydraulic pump. The pump runs as needed to maintain hydraulic pressure in the brake accumulator. Depressing and releasing the brake pedal will make the pump run, as will normal braking. It will not do it on every application, but only when needed to maintain pressure.
    The hydraulic pump will also run when first opening the driver's door after being parked for several hours.
    If you hear this repeatedly while in Ready mode, without depressing the brake pedal, there may be a problem.
    Some Gen II's and Camry Hybrids are experiencing internal pressure bleed-down in the brake accumulator that causes the pump to run every 20 seconds or so.
  9. phobix
    22
    Montreal
    Hopefully this is acceptable for those of you with reservations on downloading, I am struggling at the moment in trying to edit a video using chromebook.
  10. edthefox5
    10,096
    4,840
    Clearwater, Florida
    He's not referring to the rattle snake sound of the brake vacuum pump is he? Never listened to his sound post.
    The car always made that sound.
  11. JC91006
    16,936
    8,647
    Would this pose a possible safety risk? Another recall coming?
    SM-N900P ?
    phobix likes this.
  12. phobix
    22
    Montreal
    Thank you for the clear explanation, makes absolute sense. Fortunately, I am not hearing this sound repeatedly.
  13. phobix
    22
    Montreal
    For those of you who do not want to download the file I have posted a video here:
    WeVideo
  14. JC91006
    16,936
    8,647
    That sound is not normal, I would have it addressed under warranty before it runs out
    SM-N900P ?
  15. phobix
    22
    Montreal
    It didn't sound right to me either. Presumably you have never heard this sound from your own Gen III prius?
  16. JC91006
    16,936
    8,647
    Never heard that sound, sounds alarming
    SM-N900P ?
  17. edthefox5
    10,096
    4,840
    Clearwater, Florida
    That may be the pump normal sound just recorded in a weird angle. Where is the mic being placed to record that?
  18. edthefox5
    10,096
    4,840
    Clearwater, Florida
    And why is there an abs pump on the ground there lol. Did you find someone with that weird sound too?
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Whatever it is should be covered under 3/36 though. Hopefully you have less than 36,000 miles :eek:
    Take it in asap so it doesn't leave you on the side of the road.
  20. phobix
    22
    Montreal
    The mic was roughly roughly 3 inches away from the ABS unit. I had my wife depress the brake pedal to reproduce the problem while I had the hood open. This same sound is audible from the cabin albeit a little less pronounced.
