Normal Operating Water Temp
Discussion in 'Gen 2 Prius Technical Discussion' started by J.R. Fisher, Feb 14, 2013.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    I have view other posts that are in the correlated neighborhood you have 181-186 temps for coolant . I have measure mine on Texas early summer with temp of 190F.. ...What temp do you damage critical engine and transaxle componets??
  2. Patrick Wong
    18,210
    6,523
    When the engine coolant gets above boiling point, that is bad. What is your odometer reading, has the engine coolant been replaced at 100K miles, and have you checked the fluid level in the radiator to make sure it is full?
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Check when the car has not run for several hours, hot fluid can scald you.
