Normal windshield washer nozzle pattern?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Oct 15, 2019.
  1. pasadena_commut
    pasadena_commut Senior Member
    1,488
    446
    Southern California
    The stream patterns from the two windshield washer nozzles on my car are quite different. The passenger side streams are spread out landing far apart on the glass. However, on the driver side two streams land very close together, and all three land on the glass just above the parking position for the wiper. Is that normal?
  2. ChapmanF
    15,589
    Might be partly clogged, or just need aiming.
    WilDavis likes this.
  3. dolj
    dolj Senior Member
    7,651
    3,862
    Wellington, New Zealand
    Attached is how the RM says they should be adjusted.
    I hope that helps you.
  4. pasadena_commut
    1,488
    446
    Southern California
    That has exactly the needed info. Thanks!
  5. pasadena_commut
    1,488
    446
    Southern California
    Did this yesterday and after much fiddling a pattern very close to the one in the PDF was achieved. It would have been much easier to do this with two items I didn't have: the special Toyota nozzle adjustment tool and a pair of eyes which can focus up close on tiny objects. Made do with a long needle and a magnifying glass. This was a little tricky to do because each nozzle has two holes so the pair must be adjusted together. Move one up and the other may go down if the nozzle rotated rather than lifted. With just the one needle it was very hard to control this. The Toyota nozzle tool presumably has a slot into which the "I" shaped flange between each pair of holes fits, so one can lift and rotate separately. Anyway, for anybody else who does this, perhaps try it with two needles, that should make it much easier to control elevation vs. rotation.
