Normal?
Discussion in 'Gen 4 Prius Main Forum' started by Ryder99, Dec 6, 2022.
  1. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    I don't normally look at the door sill bjt since it gets dark at 4pm now I have noticed this. Is this normal?
  2. TGrracie
    TGrracie Member
    45
    43
    Duxbury
    2018 Prius Prime
    Looks like you got one of the illuminated door still plates
  3. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    Yes. My 22 nightshade which I picked up in Feb has the illuminated sills.
    Is the spotty lighting normal or should it be fully lit?p
  4. fuzzy1
    10,687
    I can't say for your vehicle generation, but for my own generation, it was part of an option package. Among my circle of friends with Prii, only one has it.
  5. bisco
    52,776
    the strip light does look off in the top half, but idk, i've never seen one.
  6. Mendel Leisk
    42,265
    Here’s ours, always looked this AFAIK. 3rd gen though.
    Oh, see it’s quite different. :unsure:
  7. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    I still need to look at the passenger side but I would think the lights would be on all the way up.
  8. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    2022 XLE NIGHTSHADE picked up February 11:
    Ryder99, bisco and Mendel Leisk like this.
  9. Mendel Leisk
    42,265
    Gotta say: I wish they'd offer non-illuminated door sills. Better yet, make them a relatively self-healing plastic, durable, and standard equipment on all levels. Sexy, lit-up Prius badges and brushed metal are not what I'm looking for. FWIW, our 2010 had the illuminated sills when new. I'm guessing someone was lined up to buy the car, ordered the sills, then the deal fell through. The build-date was 15 months previous, and we found it way at the back of a display/storage shed on dealership lot, covered in dust. Dealership didn't even mention them, probably to avoid us noticing the build date and history. Worked out well anyway.
  10. Tideland Prius
    16,670
    Illuminated door sills were part of the Touring Package in Canada.
  11. Mendel Leisk
    42,265
    That's what I was thinking, and that very well could be the case. I did see this in the brochure though. Maybe superseded??
  12. Mendel Leisk
    42,265
    As long as I had the brochures out, couldn’t resist, what a change in mindset, 3rd to 4th gen:
    Tideland Prius likes this.
  13. Tideland Prius
    16,670
    Well if you had the base or Premium package, you may have wanted to add it to your car so that’s why it was offered.
    Lemme check my stuff when I get home. I do remember it was a late addition to the package.
  14. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    Today I noticed the outside temp reading was blinking 37 degrees (I am not sure how long it was blinking) but then it changed to 38 degrees and stopped blinking.
    Any ideas what might have caused it?
  15. fuzzy1
    10,687
    Freezing / possible ice on road warning.
    On both my Prius and Subaru, this happens whenever the outside temperature drops to 37F. It does not continue at lower temperatures.
    Ryder99 likes this.
  16. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    @fuzzy1 i looked today when starting the car and the temp was blinking a few times. It was 13 degrees outside.
  17. fuzzy1
    10,687
    I'll have to watch closer at startup. When starting in those temperatures, I'm usually focusing on getting the climate control set for window clearing, then stepping out to clear the exterior.
  18. Tideland Prius
    16,670
    Hmm, you're right. My 2010 brochure shows the same.
    But the 2011 brochure adds it
    It could be a last minute addition that was added after the brochure was printed.
  19. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    the primes dash temp gauge blinks for 5 seconds at initial start, whenever the temps it's reading are 37 f or lower.
    Take it to mean whatever you think it might be trying to notify the driver of.
  20. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
    37F is 3C - Flashing indicates the “potential of” ice warning
    Standard warning on most cars in the UK at least
    Had it on my Toyota’s Vauxhalls and Fords
    Ryder99 and Tideland Prius like this.
