NOS for Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ozarkretiree, Sep 9, 2011.
  1. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    This reply caught me by surprise and I laughed so hard I got the dreaded coffee out the nose. Thanks
  2. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    After reviewing all the helpful replies, I think this is the best solution. Thanks
  3. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    Funny, but I agree and have discarded the thought. Fun trip through fantasy land though.
  4. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    WOW! What a great little thread.
    I too easily recall other threads where first time OPs suggested
    souping up a Prius that turned into ugly wrestling in the mud.
    I have no interest in hotting up the performance, but reading this
    thread was a pleasure... and I even learned some cool stuff as well.
    Thanks to the OP and posters.
  5. a_gray_prius
    2,927
    783
    IL
    Just don't blow the welds on the manifold, man.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    My fantasy Prius 'go fast' mod would be a 200 volt electric roots supercharger running from the HV battery. It should run out of SOC in about 1/4 mile, but that would be enough!
  7. dabize
    dabize New Member
    98
    Sudbury, MA
    I have to LOL
    I would have called it a dickshift modification, but that works..........
  8. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Nothing like a cloud of smoke to let everyone know how much we care for the environment.
    Check out the White Zombie electric dragster:
    Yeeeehawww!!
  9. tf4624
    tf4624 Active Member
    527
    51
    No way to make it faster? Lol mines faster then any stock Prius. Mines an 08
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Do you remember the Honda CRX with two engines and two transaxles? Now that was a sleeper.
    Tom
  11. a_gray_prius
    2,927
    783
    IL
    Remove all excess weight from the car - that makes it faster (it's basically what I did).
    There's a 10 or 11-second dual-engine Eagle Talon around Chicago.
  12. ETC(SS)
    7,457
    Keep the G2 stock and buy a toy.
    It doesn't have to be a 5-6 figure toy.....you can get a used bike cheaply...especially in this economy! Even my diminutive Vulcan is a hoot to (ride.)
    In my never to be humbled opinion, trying to turn a Prius into a fire breathing, asphalt smoking monster is just wrong on a lot of levels. In the first place, it can't be done...at least not cheaply. Secondly, it would be a repudiation of the G2's primary purpose. It would be like putting '33's on it and trying to do the stump jumping thing, or mounting an HSD plant into a Corvette.
    Just wrong.
    Of course this is just my 2 centavo's worth, and I respect the Pinto Chick's idea of grafting a proper drive train onto a Prius body for the shock value of being able to turn 10's with a Prius body------but at the end of the day, you'd be driving a Camaro in drag.
    On the other hand.....you're in your seventh decade, so you don't need any punk kid in his late fourties telling you how to roll.....now do you?
    Whatever you decide, good luck!
  13. nutmeg
    nutmeg just rollin'
    24
    Loveland OH, USA
    buy a mustang, red convertible. and don't complain about the gas milage. now, make THAT faster.
  14. sidecar
    sidecar Member
    342
    45
    Australia
    Camry hybrid have a 2.4 ltr 148 hp Atkinson cycle engine and 650 volt 141 hp electric drive unit using a CVT transmission. Total output is said to be 188hp, and it actually out accelerates its gas engine equivalent.
  15. macaw
    macaw New Member
    Someone did manage to fit a turbocharger on a first gen prius improving both acceleration and gas mileage. Since you have this need for speed, you should obviously one up this by putting in both a turbocharger and an e85 conversion (higher octane of e85 will allow more aggressive compression). Then publish a detailed how to with pictures along with the resultant mpg change and acceleration. Since you have a GenII not I, this will be completely uncharted territory but I'm curious about the results. Theoretically an aggressively turbocharged e85 prius should operate at a significantly better thermodynamic efficiency than the old gas versions.
    Browser Warning
  16. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    that turbo prius is a 10 series jdm only, close but not the same as what you guy's call a gen 1.
  17. drew_flux
    73
    22
    sydney australia
    my stock '04 has smoked many camry hybrids. a drive train swap is tempting though.
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    NOS!
    [ame="http://www.youtube.com/watch?v=qygYJKvD5C4"][/ame]
  19. Stormz
    Stormz Member
    105
    Perth, Australia
    Yikes! Brilliant find (pity the Honda had the NOS though) :)
  20. Stormz
    Stormz Member
    105
    Perth, Australia
