Not able to learn linear valve offset
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Nauman, May 15, 2019.
Tags:
  1. Nauman
    Nauman New Member
    Pakistan
    Hi everyone,
    Problem background : The car has a bad steering angle sensor which is showing c1231 and traction light ON. The ABS/VSC/TRAC memory was reset by mistake and it caused Linear offset undone error to popup along with ABS and Brake lights. Now I followed the learning procedure by going to ABS/VSC/TRAC / Utility / ECB Utility / Linear Valve Offset option which takes to 120sec countdown but still the problem remains though i tried 3 times. Also manual states to first go to test mode,then learn and exit test mode. But i cant make sense of how to enter test mode? is it not able to learn bcz its ot in test mode? or Can a bad steering angle sensor prevent learning of linear valve? plz guide me what im dng wrong.
  2. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    This sounds like one heck of a problem. Hopefully someone here knows the answer but I believe this is something that 99% of owners won’t have to deal with. What happened? Is this a sensor that you know goes bad sometimes?
  3. Nauman
    Nauman New Member
    Pakistan
  4. Baje
    Baje Junior Member
    26
    Barbados
    Did you get this fixed?
