Not All Blips are Created Equal
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Mar 1, 2023.
  1. qmanqman
    qmanqman Active Member
    444
    153
    CO
    This is my daughter's car that I've been driving for a few weeks so some things are new to me.
    Filled up the other day and did a 150 mile highway round trip and averaged 50 mpg. Used only one blip on the fuel gauge.
    Did the exact same thing the next day and used the next 5 blips.
    According to my math the first blip represents ~3 gallons and so dos the next 5. Does that sound about right to y'all?
  2. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    It's a Algorithum.....in the summer in Colorado my record was 120 miles before I lost 1 pip...:rolleyes:.
    Then in the winter I went 32 miles and would loose 1 pip.:cautious: go figure. The bladder in our Prii..(like my own) varies on what it can hold when depending on the ambient air temperature. you can recalibrate it with the button under the dashboard. IIRC. a quick search will tell you. I usually do this once a year in June when it is hot. (y)
    #2 ColoradoCrow, Mar 1, 2023
  3. qmanqman
    444
    153
    CO
    Found it thanks
  4. Mendel Leisk
    42,292
    Purely editorial, driving me nuts: I think "pips" would be more appropriate in the title. "Blips" are aberations, exceptions, hiccups, that sort of thing. The title may still be editable by OP.
    Simbaboy and qmanqman like this.
  5. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    Like "Janky" which was recently added.(y)
  6. ChapmanF
    18,969
    The important thing is that the blips are all given equal opportunity.
    The only 'recalibration' I know of for the gauge system is one for the inclinometers in the combination meter that it uses to adjust the fuel reading for any tilt of the car. You can press some buttons to tell it what 'no tilt' is. Which you preferably do when parked on a surface that really has no tilt, or you've just made things more interesting.
    From some of what I read, there may be people going through that procedure more often than it really needs.
    ColoradoCrow likes this.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    The fuel bladder in the Gen2 is a somewhat rectangular box made of a "flexible" material (not rubber) with pleats around the sides. As it fills up, the pleats expand (like an accordion) and the box gets taller. As it empties, the pleats fold in and the box gets shorter.
    The thing is, the folds don't usually let the bladder rise or fall evenly. One corner or side can get "stuck". The fuel level sensor is in a small sub-tank with the pump, fed by a hose from the bladder- the level between the two is equal.
    So the level sensor "reads" the highest point in the bladder at any given moment. On yours, part of the bladder has "deflated" by 3 gallons since fillup, but one corner is still high enough that the level in the subtank is unchanged.
    This is why we call it the "guess gauge". The details can be different for most any (US spec) Gen2. In summer, I can drive about 100 miles with 2 pips showing constantly on the gauge.
    But it's fairly consistent that on older Gen2's the bladder gets less flexible- esp in cold weather. That limits the total tank capacity you can use.
    qmanqman and ColoradoCrow like this.
  8. qmanqman
    444
    153
    CO
    Pips were backup singers to Gladys Knight and also Merry's brother who, along with Samwise Gamgee, accompanied Frodo on his quest to destroy the One Ring.
    And based on what has been posted about a bladder that got stuck and . . . etc., I'd say blip is fitting.
    ColoradoCrow and Mendel Leisk like this.
  9. Mendel Leisk
    42,292
    Yeah if you look up "pips" there's nothing relevant to gauges, progress bars. I think it's become popular here though. Toyota just skirts it, maybe calls them "segments" somewhere??
  10. qmanqman
    444
    153
    CO
    I tried that procedure for recalibrating the fuel gauge. It didn't work in this 2007. Step #7 is the problem. As soon as i release the ODO button it just chances modes to "Trip A" then "Trip B" etc. There is no way to "Turn the Odo/Trip off then On".
    1. Park the vehicle so as it is level,front to back and side to side.
    2. IgOn and make sure that "Trip A " is showing on the odo ( this is where we made a mistake Embarassed ).
    3. Power down.
    4. Keep your foot off the brake.
    5. Push in and hold down the Odo/Trip button.
    6. Push the Power button twice to IgOn ( not Ready mode ).
    7. Turn the Odo/Trip off then On 3 times in 5 seconds.
    8. Continue holding the Odo/Trip button until a 6 digit code appears.
    9. Release,then push again the Odo/Trip button for another 5 seconds. The 6 digit code will change to a 5 digit code.
    10. After the middle digit,of the 5 digit code,changes to "1" release the Odo/Trip button and the odometer will return to normal reading.
  11. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    Almost in step #7 Release and press the ODO\TRIP button 3 times, keep pressing the button when finished.
  12. qmanqman
    444
    153
    CO
    My bad. I was starting with the ODO in "ODO" instead of "Trip A."
    #12 qmanqman, Mar 4, 2023
  13. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    hmmm. Maybe try repeating the cycle a few times? suble differencences I'm digging for my notes on this one.
  14. qmanqman
    444
    153
    CO
    Was messing up Step 2
  15. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    ah ok. Good. hopefully that helps. I have seen a complete fuel tank swap for when he fuel pump goes. Not to hard but $1,100 for the tank assembly. :( It is not as probable as the ABS device but I have heard of it going out.
  16. ChapmanF
    18,969
    Annnd, once again, that's a procedure for resetting the "not tilted" reading for the inclinometers built into the combination meter in the dash.
    If the combination meter or the inclinometers have been removed from the dash and reinstalled, or there is some other reason to suspect the learned "not tilted" value has become incorrect, then this is exactly the procedure you're looking for.
    (And of course it's very important to park as in step 1 in a place with no tilt front to back or side to side, because what the rest of the procedure is doing is telling the combination meter "see what the inclinometers are reading right now? that's the reading for no tilt front to back or side to side.")
