Not all four speakers are functioning at a time,
Discussion in 'Gen 3 Prius Audio and Electronics' started by RamaSubbu SK, Dec 26, 2022.
  1. RamaSubbu SK
    RamaSubbu SK New Member
    Washington
    Hi all,
    In my Prius 2011, all my four speakers are not functioning at the same time. When in bluetooth mode (BluLogic) only front two speakers are functioning. In AUX and Radio mode only rear two speakers are functioning. Is that expected or is it any wiring issue?
  2. Attila Fekete
    Attila Fekete Member
    164
    57
    Budapest, Hungary
    It must be something with cabling. Radio should use all speakers.
  3. RamaSubbu SK
    Washington
    Thanks, where do I find manual on how the wiring should be done? So when I open the radio cover I can try to find miss wiring.
  4. Attila Fekete
    164
    57
    Budapest, Hungary
    I think you can find it in the Electrical Wiring Diagram - part of the service manual.
  5. Elektroingenieur
    2,515
    3,234
    Three Touring
    In Bluetooth hands-free mode, only the front speakers might be used, but for the other modes, have you tried adjusting the front/rear balance control, as described in the Navigation Owner’s Manual (PDF), pages 148–150, or the Owner’s Manual (PDF), pages 330–331?
    Before assuming it’s a wiring problem, since all the speakers are working, just in different modes, I’d start by checking the balance setting described above.
    The Electrical Wiring Diagram (more info) shows the factory-installed speaker connections, but if the car has a BLU Logic hands-free system (a Toyota accessory installed after the car was built), those connections wouldn’t be shown in the EWD or considered in the Repair Manual troubleshooting procedures.
Loading...
